976364 Posts in 139000 Topics by 6449 Members - Latest Member: boba fett September 24, 2026, 11:02 AM
RADBMX.CO.UK  |  Forum  |  Q&A, Ideas & Feedback  |  New School Help Needed!
Author Topic: New School Help Needed!  (Read 2516 times)
Offline That Swan Guy
« on: September 14, 2010, 12:11 PM »
Just about to dip my toe into buy new school parts and need some advice.
I need a threadless 1 1/8 INTEGRATED headset which will take a potts mod.
Or does it depend on the type of stem you use?
Is there such a thing out there?
Cheers guys
Nick
« Last Edit: September 14, 2010, 12:26 PM by nickswan1 »
HEYWOOD BMX
Re: New School Help Needed!
« Reply #1 on: September 14, 2010, 12:29 PM »
 The hollow compression bolt depends on if your fork(not your headset) has one as standard or if you are using a starnut.Both are available as an aftermarket part.
http://www.chainreactioncycles.com/Models.aspx'modelID=23953
http://www.winstanleysbmx.com/product/21244/Stolen_Vortex_Top_Cap
« Last Edit: September 14, 2010, 12:35 PM by VOIVOD »
« Reply #2 on: September 14, 2010, 01:17 PM »
The forks belong to a 24" Knight Proformer and are still uncut. They have nothing attached or fitted to them.
I don't have a headset or a stem yet. If it depends on the forks then am I OK to get a threadless 1 1/8 stem of my choice?
So how many bits do I actually need?  :D
HEYWOOD BMX
« Reply #3 on: September 14, 2010, 01:19 PM »
 Yep,any 1 1 /8 threadless stem will fit and you`ll need a hollow bolt/starnut setup.Just get any 1 1/8 integrated headset and bin the starnut/topcap from that.FSA Impact seems to be the most widely used integrated setup. You might need some headset spacers too,depending on the steerer tube length and these will also allow you raise/lower the stem and ensure correct bearing compression.
« Last Edit: September 14, 2010, 01:24 PM by VOIVOD »
« Reply #4 on: September 14, 2010, 01:21 PM »
Thanks for the help  :daumenhoch:
