976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 02, 2026, 07:10 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  which grease for a headset?
Author Topic: which grease for a headset?  (Read 2181 times)
« on: November 08, 2010, 09:18 PM »
evening radsters
need to get some grease for my beartrap headset but not sure which of these to go for....
this one?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280506891318&ssPageName=STRK:MEWAX:IT#ht_2103wt_1140
or this one?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280559981405&ssPageName=STRK:MEWAX:IT#ht_1908wt_1140
or something else?
http://www.westons.com/acatalog/Online-Catalogue-DUR667U.html
says the cheaper one is suitable for headsets but thought I'd check with the experts first  :daumenhoch:
cheers
Re: which grease for a headset?
« Reply #1 on: November 08, 2010, 09:21 PM »
defo the strawberry one  :LolLolLolLol: any of the others would be fine i use teflon based ones  :daumenhoch:
« Reply #2 on: November 08, 2010, 09:45 PM »
cheers brummie  :daumenhoch:
Offline brass monkey!
« Reply #3 on: November 08, 2010, 10:20 PM »
i just got some from Halfords mate, comes in a red tube..., not sure what make, but they do a good range in the bike dept... :)
« Reply #4 on: November 08, 2010, 10:27 PM »
I use Finish Line synthetic grease (you can buy it at Halfords or online from others)
Partly because it's Teflon based but mainly because it says "fett" on the front  :D :LolLolLolLol:
« Reply #5 on: November 08, 2010, 10:28 PM »
Halfords do a pink/red teflon own branded one that I use.
Lurpack is good too  ::)
« Reply #6 on: November 08, 2010, 10:36 PM »
use the same grease. thought you would have used goose fat bobba
« Reply #7 on: November 08, 2010, 10:41 PM »
I just went for the teflon one in the first link i posted - took a kmc stainless chain off them too  :daumenhoch:
did have a look in halfrauds but the only one my local store had yesterday was about a tenner
also considered beef dripping as it's an old school build but didn't want to attract vermin
sid1972
« Reply #8 on: November 08, 2010, 10:54 PM »
I just use copper grease me, dismantled the crank I did back in 83 about a year back and the bearings and cups were still fresh and so was the grease...  :shocked:
Offline bruggers100
« Reply #9 on: November 25, 2010, 12:15 PM »
Hi,
copper grease is a no no on bearings.  Its for anti-seize protection (bolts, nuts etc) rather than lubrication (bearings).  As it has copper in the grease it will eat bearing surfaces.
My advice would be to remove it from any bearings you have.
