976228 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 18, 2026, 06:05 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Resto Araya rims guide, Stage 1/2/3 & 4 completed 'updated 9/12' BLING!
Author Topic: Resto Araya rims guide, Stage 1/2/3 & 4 completed 'updated 9/12' BLING!  (Read 18906 times)
sid1972
Re: Resto Araya rims - Stage 1&2 completed (updated 4/12)
« Reply #25 on: December 05, 2010, 11:53 AM »
Hurry up Sid........... we wanna see 'em shiney  >:D :LolLolLolLol:
:shocked:  Like 'Blue Peter '-  I can show you some that I did earlier!  :LolLolLolLol:
sid1972
Re: Resto Araya rims guide - Stage 1&2 completed (updated 4/12)
« Reply #26 on: December 07, 2010, 10:50 PM »
Stage 3
Sanding and Fine Finishing:
For this stage you really need a sander, mask and googles - I'm using 60 grit paper first and then 150 as the rims have corrison and brake marks visible.
Keep the bed of the sander flat at all times, its important that you do not press on as you will burn your power tool out.  ;)
In this picture you can see that most of the marks have been removed, the one nearest still needs doing (before and after shot  :D)
For fine finishing you need, a block of wood, soapy warm water, gloves and wet/dry paper (360,400,800,1000,1200 - this is the order of use)
I tend to go round twice with each grade of paper, checking in turn for areas that require more attention. Keep the paper wet using the soapy water, this increases the life of the paper by stopping it from becoming clogged up.
This is the finish you are hoping to achieve -smooth as a smooth thing  :crazy2:
Top one completed.
Bottom one completed.
Polishing Friday.. :daumenhoch:
« Last Edit: December 07, 2010, 11:12 PM by sid1972 »
Re: Resto Araya rims guide - Stage 1/2 & 3 completed 'updated 7/12'
« Reply #27 on: December 07, 2010, 10:54 PM »
 :4_17_5:
« Reply #28 on: December 07, 2010, 11:14 PM »
Good update Sid  :)
I used to use oOven pride till I came a cropper doing some"Hard annodised " Pro Class III rims  :crazy2:
J.T Racing told me always use Caustic , big tub , big gloves and treat with respect .
You can have a pair of rims done in 15 mins usually , usually covered in black , mind  :-\
then another 15 cleaning em up  :crazy2:
might as well do them the patient,, revolvo , dippo , turn roundy treatment you do instead , much cleaner
The rims are looking good already ,,,it's all about the prep  :daumenhoch:
Offline jT Racing
  • i like bikes. :/
« Reply #29 on: December 08, 2010, 12:19 AM »
i use a mega strength formula, but i do loads of stuff at once. only takes a few seconds to remove. wash with a scouring pad in soapy water, then dry and on to whatever you are doing. easy peasy chris. Hard anno is just more anno. death strength caustic will eat your parts in minutes >:D
ding dong
Offline Munnyella
« Reply #30 on: December 08, 2010, 08:40 AM »
Blimey, 60 grit, I was scared using 240!!!, guess thats why mine still have marks then!!!
Good thread
« Reply #31 on: December 08, 2010, 09:26 AM »
Nice work Sid  :daumenhoch:
 :shocked: 60 grit with a power tool ...... your lucky you had any rims left  :D  :LolLolLolLol:  Obviously works though  :daumenhoch:
Great thread Sid , looking forward to the 'bling bling' ending  8)
Offline Dannywhac
  • return of the whac
« Reply #32 on: December 08, 2010, 09:47 AM »
Heh - just signed up and came across this thread - odd coincidence I started de-anodising a set of gold Araya Aero's on the same day you wrote this up :) Nice guide - would recommend though only using 100% caustic, as oven cleaner can pit the surface of aluminium, which isn't a bother if you're polishing, but if you want em re-anodising can lead to nightmares.......
Also found a handy container to do whole wheels in - in a local 'grow shop' - only cost £7 and will do a rim at a time.
sid1972
« Reply #33 on: December 08, 2010, 10:48 PM »
These needed 60 grit, trust me  ;)  - only went round with a sander twice and I never apply pressure as such... :coolsmiley:
Thanks for the comments folks.. :4_17_5:
sid1972
« Reply #34 on: December 08, 2010, 11:33 PM »
prety good work there fella but you would have been better off after 1200 using 1500,2000, and then finish off with a 3000 avlon pad, no marks and almost instant shine
nice one Steve, I was always told anything marks that remain after 1200,  the buffing process would remove ... going to give your suggestion a whirl, always learning.. :daumenhoch
sid1972
« Reply #35 on: December 09, 2010, 09:15 AM »
 ::)  I do that mate.. ;)
sid1972
« Reply #36 on: December 09, 2010, 08:20 PM »
Stage 4: Polishing.
You need: a decent bench grinder, mops, gloves, mask and goggles. I have added some links of the products suitable.
http://www.thepolishingshop.co.uk/acatalog/Standard_Polishing_Kits.html
Following the instructions regarding the soap first etc.  ;)
http://cgi.ebay.co.uk/150W-6-ELECTRICAL-BENCH-GRINDER-POLISHER-/270642905425?pt=UK_Home_Garden_PowerTools_SM&hash=item3f03930151
The grinding wheels come off easily to accommodate the mops - the guards need to me removed also to allow access  ;)
You can also use a drill - I have completed loads of items using one, but for the price of grinder it’s not worth the hassle.
Begin by loading the mop with soap (mop spinning) - the colour of the soap will transfer onto the mop, this will only take a matter of seconds.
Loading the mop correctly takes practice - if the item does not polish simply add more. I black build up means that you have added to much.
I start by placing the rim in the middle of the mop and pusing it through to the bottom as the mop spins, so from 3 oclock - down to 6 oclock and then off. This follows the rotation of the mop and prevents the rim from being grabbed. Repeat this process as you work round the rim, 6 to 7 times normally does the trick.
For the rims centres the process is the same, just be careful not to catch the rim or your hands.. :D
The first rim took about 25 mins to complete..
and the second about the same. First set I did about 3hrs... :P
I will take some better pics in the sunshine  8)
« Last Edit: December 11, 2010, 09:53 AM by sid1972 »
Re: Resto Araya rims guide, Stage 1/2/3 & 4 completed 'updated 9/12' BLING!
« Reply #37 on: December 09, 2010, 08:39 PM »
Nicely done Si, and to think you were going to do them for me but now they're all yours now to keep :daumenhoch: :LolLolLolLol:
Now where's the hubs? :coolsmiley:
monkian
« Reply #38 on: December 09, 2010, 08:45 PM »
Great job Si. Nice thread 8) :daumenhoch:
Rodgy1970
« Reply #39 on: December 09, 2010, 09:03 PM »
great result and great thread   :daumenhoch:
Offline Macmania
« Reply #40 on: December 09, 2010, 09:09 PM »
Nice one Sid  :daumenhoch:
Wanted: Anything MT Racing
« Reply #41 on: December 09, 2010, 09:40 PM »
« Reply #42 on: December 09, 2010, 10:16 PM »
nice thread si,some good pointers there,i go about my polishing in a totally differant way.i was lucky enough the other day to just strip a rim of the ano and auto sol it to a shine as good as one that id used three differant mops and soaps on that took 7 hours!!the autosol'd one took an hour :crazy2:
« Reply #43 on: December 09, 2010, 10:28 PM »
Nice results Sid  :4_17_5:
Great thread to mate  :daumenhoch:
simo27
« Reply #44 on: December 09, 2010, 11:03 PM »
Great thread ! Love it!  ;D
sid1972
« Reply #45 on: December 10, 2010, 05:56 PM »
thanks for the comments folks.   :4_17_5:
just got to polish the hubs and build the feckers now!.. :P
« Reply #46 on: December 10, 2010, 06:07 PM »
Top work Sid
« Reply #47 on: December 10, 2010, 11:22 PM »
Bling 8)
Offline Munnyella
« Reply #48 on: December 10, 2010, 11:34 PM »
Fantastic work, and a nice style/colour of house coat too, beats my dressing gown any day!!!
« Reply #49 on: December 12, 2010, 02:17 PM »
Excellent resto that  ;)
