976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 02, 2026, 03:02 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  11/8 to inch
Author Topic: 11/8 to inch  (Read 1812 times)
motomagII
11/8 to inch
« on: December 03, 2010, 06:48 PM »
can anyone explain how to convert inch fra,me to inch 11/8 forks fitting pleasa3e
whoops thats not what i meant lol other way round lol
inch and 1/1/8 frame .fitting inch threaded forks is what i want doh
« Last Edit: December 03, 2010, 07:10 PM by motomagII »
Offline fischflo
Re: 11/8 to inch
« Reply #1 on: December 03, 2010, 06:59 PM »
http://www.radbmx.co.uk/forum/index.php'topic=113025.msg1103236#msg1103236
 ->http://www.radbmx.co.uk/forum/index.php'topic=53719.0
 ->http://www.bikeforums.net/archive/index.php/t-510410.html
 >http://www.radbmx.co.uk/forum/index.php'topic=72502.0
Thanks, guys! ;)
That "1978 melded with 2007 technology" hacking sounds absolutely doable
So off to  finding a (new school) steerer tube race matching both the forks and a 1" cup
and possibly also an old 1" bearing cage matching both the forks and the race
...and a headset a dp or ammaco could agree with  ::)
hope t'helps ;)
« Last Edit: December 03, 2010, 07:04 PM by fischflo »
motomagII
Re: 11/8 to inch
« Reply #2 on: December 03, 2010, 07:11 PM »
whoops got it wrong way round lol
Offline john4130
Re: 11/8 to inch
« Reply #3 on: December 04, 2010, 08:45 AM »
i did this a few years ago, i bought shims from somewhere that fitted into the frame but there was no chance of the cups going in. i found the perfect way of doing it was to measure the length of you're headtube and cut a piece of 0.7mm thick aluminium sheet slightly shorter than your headtube and roll it to make a pipe. then use a rubber mallet to insert it into the heatube. it takes a little time to get the pipe just the right size circumference so the ends are butted together and not overlapping but when the cups go in their nice and tight. i used this setup for years with no problems at all.
Offline kev-s
Re: 11/8 to inch
« Reply #4 on: December 04, 2010, 05:07 PM »
Offline john4130
Re: 11/8 to inch
« Reply #5 on: December 05, 2010, 09:46 AM »
http://www.billys.co.uk/english/group.php?prod=hsid-reduc-a
think that was the one's that i tried but didn't work, they fitted the frame but no chance of the cups going in. unless they sent me the wrong ones.
