976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 02, 2026, 10:00 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Tuff Wheel help!
Author Topic: Tuff Wheel help!  (Read 2022 times)
Tuff Wheel help!
« on: January 17, 2011, 04:46 PM »
Guys hi. I'm desperate to complete my 85 master but recently I bought a tuff from someone that put it in neat bleach without any grease protection and the alloy hubs are fooked  :'( Totally shot with no way of polishing them up to save them.
I have another cracked tuff which has nice hubs, so I want to remove them and get them on to this one. Now what is the best way of removing these rivets? And can anyone do this for me? I know I need to get the right bolts which could be tricky to track down also, does anyone know the best place to get these and are there any about which doesn't have that X screw for the other end of the bolt? I'd prefer bolts either end, but ideally not the screw looking ones. This was the last thing I wanted to do but the hubs just cannot be saved  :'(
Any help will be greatly appreciated.
Many thanks,
Matt  :daumenhoch:
Offline stfc
Re: Tuff Wheel help!
« Reply #1 on: January 17, 2011, 04:52 PM »
WHAT HAVE YOU TRIED ON THE HUBS REGARDING POLISHING??   oops caps on ..  ???
« Reply #2 on: January 17, 2011, 04:54 PM »
THe hardest thing is to find a similar rivet or a machine shop/engineer that can re-revit them for you.  Post up some pics of the hub as it may well be salvageble  :daumenhoch:
« Reply #3 on: January 17, 2011, 05:00 PM »
Demmel to cut them right back as its pitted to hell  :'( looks like the surface of the moon  :shocked:
« Reply #4 on: January 17, 2011, 06:18 PM »
I'll take some pics tomorrow when its light  ;)
Offline oldtired
  • Dirty Old Man
« Reply #5 on: January 17, 2011, 06:46 PM »
skyway replacement hubs had a philips pan head bolt with them i seem to remember ?  so it would  look just like a swapped hub , from bitd,   reason being is to allow as much room as possible on the cog side. if the bolt head is to big you'll turn it into a fixie when you bung the chain on   :LolLolLolLol:
« Reply #6 on: January 18, 2011, 10:53 AM »
you could buy the nuts and bolts from b & q for the hubs.i got some from there myself in the past.
have a word with jay how he done his blue hubbed tuffs and im sure rombloke dave had an idea with the rivots a while back.
« Reply #7 on: January 18, 2011, 05:36 PM »
Matt do not remove the rivets, call me & I will tell you how to do it  8)
« Reply #8 on: January 18, 2011, 07:39 PM »
I'll do that chris mate, thanks  :daumenhoch:
Offline oldtired
  • Dirty Old Man
« Reply #9 on: January 18, 2011, 10:39 PM »
+1 on that, arn't they a bit fatter on one side , because of the way they are made, i think if you pull em through the wrong way it will crack the wheel , might be wrong though?
