976302 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 30, 2026, 08:01 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  bottom bracket query
Author Topic: bottom bracket query  (Read 2001 times)
GavinKent
« on: February 19, 2011, 01:50 PM »
hi all
i'll try to explain this as best i can.  i bought a mongoose crank to replace the generic one i have on my cali.  i took it apart and when i started fitting the chain wheel on to the new crank, the nut didnt do up fully - there is one washer/spacer, but it seems on this crank i'd need two of them to make up the space .  i checked the bottom bracket packet which i'd kept and there is no extra washer.  am i right in thinking it just needs another washer, and can i just purchase one of those?
hope this makes sense and would appreciate some advice
thanks in advance
gav
HEYWOOD BMX
Re: bottom bracket query
« Reply #1 on: February 19, 2011, 01:57 PM »
 :) Do you have any pics and show me the part you need? I have loads of BB bits spare :daumenhoch:
Hootski70
« Reply #2 on: February 19, 2011, 02:13 PM »
Are you using a genuine goose b/b , as the older goose opc's were 28tpi , normal bb 24tpi .
GavinKent
« Reply #3 on: February 19, 2011, 02:43 PM »
no, afraid this isnt a goose bb - here is the pic - you'll see the space - it's like the threaded bit on the crank doesnt go down far enough to enable the nut to tighten up completely
thanks both -
oldskooldayz
« Reply #4 on: February 19, 2011, 02:50 PM »
Looks to me like that is the wrong nut buddy
not an old school type from all the ones ive fitted
it should have a recess on the flat side of about 1/2 cm if that makes sense to ya as thats what clears the gap
heres a pic of the type you should be useing
« Last Edit: February 19, 2011, 02:55 PM by oldskooldayz »
GavinKent
« Reply #5 on: February 19, 2011, 03:01 PM »
ahhhh, right - i see - in that case, i need to buy another bottom bracket - cool, at least i now know where im going wrong
thanks a lot
gav
oldskooldayz
« Reply #6 on: February 19, 2011, 03:03 PM »
loads for sale on here mate maybe voivod has a complete one for ya  :daumenhoch:
if not i might but ask him first  :daumenhoch:
« Last Edit: February 19, 2011, 03:05 PM by oldskooldayz »
GavinKent
« Reply #7 on: February 19, 2011, 03:06 PM »
thanks all
Offline stfc
« Reply #8 on: February 19, 2011, 08:30 PM »
Failing that sell me your crank and buy another, you,ll never find a mongoose b/b  ;)
