976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 24, 2026, 12:05 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  total b**ls up
Author Topic: total b**ls up  (Read 2828 times)
motomagII
total b**ls up
« on: May 07, 2006, 09:14 AM »
well i have been total idiot got my new frame didnt really look at it closely just gave it to weston to paint it for me and started buying the parts to build it .got all the bits etc together then got the frame back yesterday eve .looked at the frame thought nice paint job but summat isnt right .got up this morning thought right time to build it .looked at it again and the penny finally dropped ive gone and bought a 14mm rear acle 13t salt hub and alex rim and the dropout on the rear are 10mm .b******ks .so is there anyway of changing the axle in the salt hub to 10mm or am i stuffed.what a plank .
Re: total b**ls up
« Reply #1 on: May 07, 2006, 09:19 AM »
carefully grind the drop outs
fruity phil did his fbm
Re: total b**ls up
« Reply #2 on: May 07, 2006, 09:21 AM »
get thread chaser you can cyt down axle if you dare slot it some come slotted them re chase thread to clean threads ive done it before if you are technically minded piece of cake.
motomagII
Re: total b**ls up
« Reply #3 on: May 07, 2006, 09:21 AM »
my dropouts are minutely small they are only about 30mm width by about 2 inch long .
motomagII
Re: total b**ls up
« Reply #4 on: May 07, 2006, 09:23 AM »
tech minded me not really i can tighten the wheel nuts up okay if that is classed as technical  :LolLolLolLol:
Re: total b**ls up
« Reply #5 on: May 07, 2006, 09:29 AM »
get a pict of the drop outs up please greg so we can see em
and im sure you can change the axle if its sealed bearings
Re: total b**ls up
« Reply #6 on: May 07, 2006, 09:33 AM »
slot the axles then
motomagII
Re: total b**ls up
« Reply #7 on: May 07, 2006, 09:34 AM »
Re: total b**ls up
« Reply #8 on: May 07, 2006, 09:35 AM »
you could borrow these but who i got them from spoked them up wrong way so i got to re build em.
motomagII
Re: total b**ls up
« Reply #9 on: May 07, 2006, 09:40 AM »
can i buy a 10mm axle cassette wheel do they exist ,.the easy option would be to sell the wheel and get another .which would be a shame as its nice wheel.
Re: total b**ls up
« Reply #10 on: May 07, 2006, 03:22 PM »
mm not much room for grinding em out is there
