976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 29, 2026, 04:04 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Spoke lengths . . .
Author Topic: Spoke lengths . . .  (Read 2733 times)
The VW Doc
Spoke lengths . . .
« on: April 19, 2011, 12:17 PM »
Hi all - I have a bit of a problem and I hope you guys and girls can help me out.
I stripped a pair of original Weinmann rims, with Sturmy Archer hubs (from a Mk1 Raleigh Super Burner - The gold coloured one) down at the weekend with a view to refurbishing them.
Due to the ammount of corossion all the spokes either were or did bend very badly or snapped off (either at the nipple, or between 2-3" up from the nipple) leaving me with a load of uslelss spokes that I cant guarantee to get an accurate measure of to allow me to replace them.
Would anyone know for sure how long the spokes need to be so I can order up some replacements?
Pleas help!
Re: Spoke lengths . . .
« Reply #1 on: April 19, 2011, 03:32 PM »
Are they a large flange or small flange hub?
Offline Munnyella
« Reply #2 on: April 19, 2011, 05:23 PM »
You may find this info on burnerworld, I think they have a tech data section.
dirtskirt
« Reply #3 on: April 19, 2011, 07:51 PM »
For a 3 cross pattern with low flange hubs you need 194mm or if they are high flange (prob not) then you will need 183mm for a  3 cross pattern..
The VW Doc
« Reply #4 on: April 19, 2011, 08:26 PM »
Cheers guys!
I am pretty sure the are small flange hubs
I have cropped out a photo of a (pre assembled) wheel and the hub so you can see
194mm sounds like what it is then :)
bof
« Reply #5 on: April 19, 2011, 08:35 PM »
Just measure the bits you have then thats the length u need. Its the guage u might struggle to match
Offline Dannywhac
  • return of the whac
« Reply #6 on: April 19, 2011, 08:38 PM »
Buy yourself one of these:
http://cgi.ebay.co.uk/6-Inch-150-MM-Digital-Vernier-Caliper-Carbon-Fibre-/300539288266?pt=UK_Measuring_Tools_Levels&hash=item45f9899aca
Have a look here for the calculator:
http://www.wheelpro.co.uk/spokecalc/
And here for the A,B,C,D etc help:
http://www.wheelpro.co.uk/spokecalc/help2.html  - edit - see the 'help' button on that page - linky doesn't take you to it for some reason.....
And then goole your rim name and 'ERD'
Looks complicated but'll help you verify before buying  :daumenhoch:
« Last Edit: April 19, 2011, 09:17 PM by dannywhac »
The VW Doc
« Reply #7 on: April 20, 2011, 08:25 AM »
Cheers guys!
I guess the safest way will be to piece together the bits I have and see if I can get an idea of length
If that is inconclusive then to measure then up as dannywhac suggests
