976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 26, 2026, 10:18 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Crank thread help please
Author Topic: Crank thread help please  (Read 2166 times)
Offline Taipan
« on: May 29, 2011, 11:38 AM »
Had a OPC crank re-chromed but the chromer has chromed up to the first part of the thread a bit to much :(,I think I need to have it re-cut,can anyone help or advise,thanks
Re: Crank thread help please
« Reply #1 on: May 29, 2011, 12:01 PM »
Thread the pedal in from the other side that should help clean the thread out  :daumenhoch:
Offline oldtired
  • Dirty Old Man
« Reply #2 on: May 29, 2011, 12:04 PM »
pedal or bb thread?
« Reply #3 on: May 29, 2011, 12:09 PM »
pedal or bb thread?
AHA!  Didn't think of that  :-[  If it is the BB, then a little patience and some lube will be required but you should be able to clean the thread out using the BB nut failing that you may need to go to a machine shop and see if they have a thread cutter they can run over it for you to clean the thread up  :daumenhoch:.
Offline Taipan
« Reply #4 on: May 29, 2011, 12:15 PM »
yep its the bb thread,cant do it with the bb nut its really tight and seems to be making it go on cross threaded if I pushed it? the threads are perfect bar the first one :(
Offline Gnarlyscoots
  • BANNED
« Reply #5 on: May 29, 2011, 12:16 PM »
If its a pedal thread that needs clearing, do as below but be careful as you do as you might find the chrome will crack  :daumenhoch:
Other than that, get this http://cgi.ebay.co.uk/ROEBCUK-1-2-UNF-SECOND-TAP-20-TPI-USED-MINT-/220789441083?pt=LH_DefaultDomain_3&hash=item336813823b
I,m sure that pedals are 20TPI (20 threads per inch)
This will do the job better than risking fooking up ya pedal thread  :daumenhoch:
BANNED
  • BANNED
« Reply #6 on: May 29, 2011, 12:20 PM »
KK  ;D was writing that when new post appeared  :daumenhoch:
What size diameter is the thread ???
BANNED
Offline Taipan
« Reply #7 on: May 29, 2011, 12:57 PM »
havent a clue?
Offline oldtired
  • Dirty Old Man
« Reply #8 on: May 29, 2011, 01:13 PM »
if you have got or know any one with a buffer , theres a plenty of members on here with em one might be near by,  use some first cut compound to tidy up the thread where the chrome has gone over , should be able to clean up the thread, tape the crank to protect the arm, finnish of with the normal other two compounds to shine up the the thread again
