976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 26, 2026, 10:39 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Bullseye Help Please!!!
Author Topic: Bullseye Help Please!!!  (Read 2400 times)
Offline Jamroll
« on: June 15, 2011, 04:04 PM »
So just built me wheels, and am having a little trouble getting the freewheel on, another story.
Anyway, haven't got my frame at moment as its getting some work done but I do have the front forks, looking at the hub width including the collar it looked a little big for the width of the forks, tried them and yep to fooking big  >:( Can i "strech" the forks about 5mm to make them fit, wots the easiest way of doing this without any damage to the finish or does anyone one if Bullseye make thinner collars???
Edit - should point out i was using the thinner collars supplied  :)
Al
« Last Edit: June 15, 2011, 04:39 PM by jamroll »
Offline hotdog
Re: Bullseye Help Please!!!
« Reply #1 on: June 15, 2011, 04:47 PM »
The spacers on my Bullseye front hub are 9mm. Inside width of my forks are 100mm. Plus I have a 4mm alloy washer between each spacer and the inside of the fork (if that makes any sense to you) to make up the gap.
Offline Jamroll
« Reply #2 on: June 15, 2011, 05:03 PM »
I haven't got a gap, with the collars thet are 4-5mm to wide for the inside of the forks  :(
Inside width on my forks is 95mm...
« Last Edit: June 15, 2011, 05:08 PM by jamroll »
Offline hotdog
« Reply #3 on: June 15, 2011, 06:01 PM »
So the problem lies with your 95mm fork width. I'd try and pull the forks apart,it's only 2.5mm each side but keep an eye on the extra pressure this has on the bearings. Can't really think of another solution. Good luck anyway.
Offline Jamroll
« Reply #4 on: June 15, 2011, 06:50 PM »
Does anyone know if Bullseye make smaller collars? Really dont want to stress the beings on the hub or the welds on the forks  :(
Offline hotdog
« Reply #5 on: June 15, 2011, 07:05 PM »
Drop Bullseye an email.
STEVEN@BULLSEYECYCLEUSA.COM
Offline Taipan
« Reply #6 on: June 15, 2011, 09:44 PM »
Ok,here I am what you want? ???
1mancity2
« Reply #7 on: June 16, 2011, 07:14 AM »
If the collars are seperate you could flat sand a couple of mm of each one, would take minutes if they are ally and you use a rough grit, just remember to finish with a fine grit.  :daumenhoch:
Offline Jamroll
« Reply #8 on: June 17, 2011, 12:09 PM »
