976229 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 22, 2026, 10:21 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  seat post stuck HELP!!
Author Topic: seat post stuck HELP!!  (Read 4080 times)
elmo
« on: May 18, 2006, 08:26 PM »
i have got an alloy renthal seat post stuck in my dp firebird its been sat in oil for a week but wont budge.
can i heat it or will it damage the frame? any more ideas thanks
Re: seat post stuck HELP!!
« Reply #1 on: May 18, 2006, 08:29 PM »
diesel or the stuff that eats alloy
they use to strip anno of alloy
caustic soda
« Reply #2 on: May 18, 2006, 08:30 PM »
second bit if ya dont want the seat post lol
elmo
« Reply #3 on: May 18, 2006, 08:33 PM »
sounds like a good plan mate thanks  :D
adeshere
« Reply #4 on: May 18, 2006, 08:50 PM »
have you not tried putting the post in a vice and turning the frame ?
« Reply #5 on: May 18, 2006, 08:56 PM »
that should work
elmo
« Reply #6 on: May 18, 2006, 09:03 PM »
alloy is too soft to put in vice it just turned .drilled a hole through the alloy and put metal pin in then clamped to the vice which held it in place got more flex out of the frame but post did not move.it is really stuck :'(
« Reply #7 on: May 18, 2006, 09:12 PM »
fill it up with caustic soda
watch ya eyes and dont breath it in
it will be all gone in the morn lol
just pour out the mess after
elmo
« Reply #8 on: May 18, 2006, 10:14 PM »
will try the caustic soda over the weekend friend has got the right place to use the stuff so fingers crossed will work ok let you all know sunday
steve
« Reply #9 on: May 18, 2006, 10:16 PM »
take your old stem, and clamp it to the seat post
-do it up real tight
-then, instead of trying to twist, whack it straight down
« Reply #10 on: May 19, 2006, 11:02 AM »
sometimes caustic is the only way....
« Reply #11 on: May 19, 2006, 11:12 AM »
make sure you block any holes.
its worked quite well taken half of the post away, but it was a very thick post, so i need to do it again, but i ran out of caustic. i kept topping it up cos you pour a bit in then it all froths up over the top. you need to keep adding a bit more, and occasionally tipping out the sludge.
remember, gloves and dont breathe in the fumes....do it outside, and dont get it on your skin it burns like feck.
« Reply #12 on: May 19, 2006, 11:58 AM »
i'll try that on my pk ripper ;)
elmo
« Reply #13 on: May 19, 2006, 05:08 PM »
Hi  oberonspacefruit how long did that take you to do ?
should i do the topping up bit or leave it overnight?
« Reply #14 on: May 19, 2006, 06:45 PM »
i couldnt leave it overnight, cos the stuff literally flies out the top.
there is very little liquid left in the tube, due to spillage, thats why i had to keep topping it up.
Offline Waxintaxin
« Reply #15 on: May 19, 2006, 07:37 PM »
Nice clear instructions , but wear goggles as this will hurt in your eye
« Reply #16 on: May 19, 2006, 07:38 PM »
you only got one eye then rich
Offline Waxintaxin
« Reply #17 on: May 19, 2006, 08:12 PM »
1 eye would be an accident
both would be foolish
Rich :)
elmo
« Reply #18 on: May 22, 2006, 10:58 PM »
well used all the costic going to have to get some more.
the renthal seat post was really thick but it is thinning out now
cheers for all the advice
« Reply #19 on: May 23, 2006, 08:11 AM »
slowly slowly catchy monkey.
