976299
crissy_criss
June 24, 2026, 05:32 PM
potts mod help needed.......
Topic: potts mod help needed....... (Read 1871 times)
bigfatolly
Cherry Picker
July 09, 2011, 10:25 PM »
I have an annoying problem which i cant get to the bottom of.
I have a Tuf Neck Freestyle stem with its original hollow bolt and a clarks powerglide cable,exactly the same parts as i had BITD.
BUT I CAN'T GET THE FOOKING CABLE THROUGH THE HOLLOW BOLT
I also had this problem on another bike,again a tuf neck stem, but as it was for show i cut the outers so it looked like it was through,problem was the brake wouldnt work.
This time it has to work as its a rider.
Any ideas,can't understand it as i had these exact same parts 25 years ago with no problems?
oldschoolace
Team Moderator
Double Flip Whip
Bodger
Re: potts mod help needed.......
July 09, 2011, 10:30 PM »
Check the inside of the bolt for a perished outer cable. I had one recently and it took me a while to work out what was up. I did try burning it out but when that failed i just drilled it out with one or those long masonry bits
bigfatolly
Cherry Picker
July 09, 2011, 10:51 PM »
Deffo not that mate,the tuf neck on the other bike was NOS......
Have looked down this one and no blockages
animal
Team Moderator
BMX Nerd
MRD Loony & proud
July 09, 2011, 11:09 PM »
Buddy it will never work
Hollow stem bolts only allow Dia Compe thickness cables through
Clarks r thicker and don't work, trust me tried it bitd
If u cut them it wll defo not work in 2 parts gotta b a continuous cable
oldschoolace
Team Moderator
Double Flip Whip
Bodger
July 09, 2011, 11:13 PM »
Dont mean to sound funny but it may be worth another look. On mine the outer had split at the top of the bolt, from wear i guess, and looked for all the world like you would imagine the inside of a bolt to look. It was only when i looked closely at the other end of the bolt that a vary small tatty piece of the outer gave it away
bigfatolly
Cherry Picker
July 09, 2011, 11:30 PM »
Steve,i tell ya now mate,i had a tuf neck freestyle stem BITD with a dark blue clarks powerglide through it,they were all i could afford
IT HAS TO WORK
BENDYCAT ELEVENTEEN
Berm Worm
"Click here for link"
July 10, 2011, 11:43 AM »
backing up what was said above
Clarkes cables are thicker than a standard cable
i have a few to check
Betty
900 Air
July 10, 2011, 11:48 AM »
Early potts mod bolts were drilled just to take the inner cable through, use a lever stop against the bolt (above and below) or get it drilled out big enough to take the outer cable...
2 minutes turkish...
john4130
Look Back
July 10, 2011, 12:25 PM »
i always used powerglide cables bitd and there is a way of doing it. first thing to do is remove the teflon sleeve from inside the cable, then you have to cut the cable outer, measure from the lever to the top of the stem bolt as the cable would run then add a couple of inches and cut the outer. shave the plastic of the end a couple of inches and stick it in the stem bolt, then take the other half of the outer and shave off about 4 inches of plastic and sick that up the forks into the stem bolt. then insert the teflon inner through. then set up the brake as normal. it works a treat.
oldtired
540 Air
Dirty Old Man
July 10, 2011, 04:17 PM »
fook me Bendy's pm box just filled up
bigfatolly
Cherry Picker
July 10, 2011, 04:28 PM »
I will try that trick mr John 4130,i know i never did that bitd though!!
bigfatolly
Cherry Picker
Reply #11 on:
July 10, 2011, 11:18 PM »
Quick update.
I cut a piece of thin cable outer to put through the hollow bolt and cut the powerglide outer into 2 bits and joined it each end with insulation tape.
Looped it up nice and tight and voila- it works.
Never did this bitd though.
Clarks must have made their cables in 2 thicknesses unless my memory is hazy and there was another make in dark blue that i used.
I never had dia-compe cables bitd,first one i ever owned was bought on here
