976229 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 22, 2026, 12:34 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Another paint question please help...UPDATE** NOW WITH PICS
Author Topic: Another paint question please help...UPDATE** NOW WITH PICS  (Read 2689 times)
d14vd_h
got my raleigh team burner back from the coaters today
top job but i think the colour code suggested over on the burner site is wrong as the white has came out creamy rather than bright white...
phoned him up and the coater says he would have to blast it all and repaint it again so another 50 quid
not sure i can afford or justify this.....
therefore i was gonna look at spraying the white section myself
i could do with any advice on this!
how many cans how to avoid runs etc
the powder and lacquer thats on it just now is such a good job im worried i ruin it.
now the pics
used paper and my bright white seat post ofr comaprision
« Last Edit: May 24, 2006, 11:43 AM by d14vd_h »
Re: Another paint question please help...
« Reply #1 on: May 24, 2006, 11:16 AM »
its worth a try mate
it probably wont take much paint to cover it
mask off the other colours.
key the white lightly, with a scratch pad. wipe all the dust off
get the frame nice and warm
spray it in very light coats, leaving 10 mins between each one.
do it until it looks covered and even.
then put the frame somewhere really warm (maybe in the airing cupboard, once the paint has dried) and leave it for a WEEK to harden.
« Reply #2 on: May 24, 2006, 11:20 AM »
its nearly impossible to spray a frame withour sags, or overspray. just do lots of coats, wait for it to harden,flat it with wet and dry, and a then a polishing compound.
d14vd_h
« Reply #3 on: May 24, 2006, 11:27 AM »
cheers lads so no need to lacquer sepratley?
do you guys hang the frame with say cardboard behind it in the garage or something to paint it??
so its inevitabloe the finish wont be perfectly smooth as say powdering
ill get some pics up and u can see if im being a drama queen
« Reply #4 on: May 24, 2006, 11:33 AM »
you can laquer it after you put the base colour down.
Jazzchimp
Re: Another paint question please help...UPDATE** NOW WITH PICS
« Reply #5 on: May 24, 2006, 02:08 PM »
Can't you just cut it back?
« Reply #6 on: May 24, 2006, 02:15 PM »
i see what you mean, it is a bit more of a cream colour. coated with the bb cups in too.
« Reply #7 on: May 24, 2006, 02:23 PM »
go around the edge of the bb cups carefully with a stanley to cut the paint
then whack em out
then either strip em, or fit new ones. or get some old greasy ones and clean them up. they always clean up nice unless they are rusty
do this before you spray. hammerite, although scorned on here, would do the job.
« Reply #8 on: May 24, 2006, 02:28 PM »
must admit powder is nice, id be tempted to do the other bits in the same colour, or just bite the bullet and re powder, rather than painting on top of powder coat. hammerite would sort it, but i warn you now, its a black art. it reacts to almost anything that it touches for some reason.
« Reply #9 on: May 24, 2006, 02:30 PM »
get it powdered in just plain white and paint the blue bit after
the powder coaters i go to charge 25 quid plus vat and they do a wicked job
d14vd_h
« Reply #10 on: May 24, 2006, 02:56 PM »
bugger it i'll just keep as is its pretty much white it must be literally a shade away
are the bearing cups ok to be left in painted?
« Reply #11 on: May 24, 2006, 02:58 PM »
its up to you
i'd get em out and put in fresh clean ones
not sure how bearings against paint is gonna perform in the long run
scary_leary
« Reply #12 on: May 24, 2006, 08:03 PM »
fook sake, dont spray it yourself... youll regret it
leave it or re powder all of it.
