976298 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 21, 2026, 08:49 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Tuf neck /Pro neck Shaft Extraction
Author Topic: Tuf neck /Pro neck Shaft Extraction  (Read 1480 times)
Offline crazycraig
« on: September 09, 2011, 09:18 AM »
How the fook do these things come out ? Are they threaded ?
Old School BMX only
Cash is King
Offline hazzajoe
Re: Tuf neck /Pro neck Shaft Extraction
« Reply #1 on: September 09, 2011, 09:29 AM »
not sure if all them are, but mine is.
I clamped the stem using soft jaws in a large bench vice and using a socket and power bar . I cracked it off the normal way. Anti-clockwise. around the large bolt head I used electrical tape to protect the face of the stem from the socket.
I'm sure people have better ways.  :daumenhoch:
Offline crazycraig
« Reply #2 on: September 09, 2011, 09:31 AM »
Are you talking about the shaft or the large nut hazza ?
Old School BMX only
Cash is King
Offline crazycraig
« Reply #3 on: September 09, 2011, 11:37 AM »
So they are not threaded ? This threads for you Snav !!!! 3 into 1 does go
Old School BMX only
Cash is King
« Reply #4 on: September 09, 2011, 01:20 PM »
craig, heat up the alloy with heat gun/paint stripper gun, and get the alloy red hot, it will expand enough to allow just a light tap with a lump hammer on top of the big nut, better still send it to CCA, they do it all for you if your having it re-anoed...
Offline crazycraig
« Reply #5 on: September 09, 2011, 06:58 PM »
Cheers chaps  :daumenhoch:
Old School BMX only
Cash is King
