976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 19, 2026, 05:19 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Fricko post
Author Topic: Fricko post  (Read 4848 times)
Fricko post
« on: December 19, 2011, 02:11 PM »
Still working on my snapped alloy renthal post in the GTS - about a month now  ::) it's over at my mums place and each time i go there i wash out and fill again OA/Hotwater
looks like i shall be done by 2019  ;D  then a bit of welding  ;)
rad_pitt
Re: Fricko post
« Reply #1 on: December 19, 2011, 02:55 PM »
You sure that's oxalic acid B?  ???
motomagII
Re: Fricko post
« Reply #2 on: December 19, 2011, 03:20 PM »
bubbling more like fairy liquid than axalic acid is that
Offline Peter J
  • I have issues
rad_pitt
Re: Fricko post
« Reply #4 on: December 19, 2011, 03:35 PM »
Could you not get it machined out? There was a guy on recently, a relatively new guy with a mid school GT and drilled the post completely out. He did it at work if I recall  ???
Offline 58 delray
Re: Fricko post
« Reply #5 on: December 19, 2011, 03:59 PM »
have you tried caustic soda?
Offline Dannywhac
  • return of the whac
Re: Fricko post
« Reply #6 on: December 19, 2011, 04:03 PM »
X2 - you'll be there longer than 2019 using OA.
Re: Fricko post
« Reply #7 on: December 19, 2011, 04:39 PM »
Tis my mistake  ;D  i have been using caustic soda on the seat post - the bubbling might be a bit of washing up liquid on the pipe brush i used last after giving it a good clean out of all the sludge - acid oxide was for the rust parts i have been doing  ;)
it will come out soon i'm hoping  :angel:
ozone
Re: Fricko post
« Reply #8 on: December 19, 2011, 04:44 PM »
Looks like it's wide enough to fit a hacksaw blade down the inside of the post now.  I'm sure people on here have got them out using that method.  Might be worth a shot...
Re: Fricko post
« Reply #9 on: December 19, 2011, 07:22 PM »
Would it be easier to just replace the whole tube?
Re: Fricko post
« Reply #10 on: December 19, 2011, 07:28 PM »
should have dissolved easy by now  :shocked: I got daves out his GT in 4 days  ::)
Offline stfc
Re: Fricko post
« Reply #11 on: December 19, 2011, 10:18 PM »
 have used before in no particular order ... Electric saw as used at any decent garage, 3 cuts  down the sides 10 mins and out , Heat , Old stem down the seat post tighten up heat the post , twist etc 20 mins , diesel ... didnt work ... Good luck , on that I would go down the leccy hacksaw route ...
Offline Darren KAP
Re: Fricko post
« Reply #12 on: December 19, 2011, 10:25 PM »
    I used a air saw on one of Digglers frames , took abit of time but came out in the end  :daumenhoch:
    i did it for free as he offered me man sex for payment  :shocked: ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,  :LolLolLolLol: :LolLolLolLol:
Re: Fricko post
« Reply #13 on: December 19, 2011, 11:35 PM »
while i was waiting for it to do it stuff it gave me a chance to try and find some lost bits - a year and a half later i found the packet i lost containing my DX end caps and the old set that were in the pedals - then i found a lost renthal post (used and needs work ) cheers for the one you sold me Daz  ;)
I think the seat post is well seized all the way down and that is why it is not coming out well  ::)
skyway67
Re: Fricko post
« Reply #14 on: January 04, 2012, 11:18 PM »
how much of the seat post do you reckons left in the frame ?
theres a good chance i could drill this out for you  :daumenhoch:
Re: Fricko post
« Reply #15 on: January 05, 2012, 12:37 AM »
It's got a hole in the side of the inside of the tube i can feel
I think that the thing is that is has welded all along the tube and not just a bit at the top - this is why it's taking it's time
it's getting more out each time i look at it
this is a build that i can work on as i still haven't got all the parts and the mags need doing - so i just work on one of the others while this is doing
thanks for the offer but it will come out in the end
i'm gonna need a good welded - seat tube has been cut at some point in the past and just need a new bit in it's place or weling adding to it to close up the parts ? any one ? a name ?
cheers B  ;)
Offline Dannywhac
Re: Fricko post
« Reply #16 on: January 05, 2012, 01:31 PM »
Sawzall or Animals the fellas for that BE :)
skyway67
Re: Fricko post
« Reply #17 on: January 05, 2012, 07:19 PM »
no problem just that i have my own engineering machine shop and work for myself  :Great_Britain:
this is my skyway frame having the rust and muck honed out
i was struggling to get a seat post in............. the exact opposite to the trouble your having
i can also make wheel spacers brake parts crank washers etc
 and cylinder heads are a speciality  :LolLolLolLol:
daz
Re: Fricko post
« Reply #18 on: January 05, 2012, 08:43 PM »
 ;D now you fricking say Daz  ;D
It's nice to see the pic's now to back up the talk  ;)
i think you may have some pm's from members and just what you can do
do you do any welding ?
cheers B  ;)
skyway67
Re: Fricko post
« Reply #19 on: January 05, 2012, 08:56 PM »
i can weld but i only have a basic mig welder
this seat mast of yours needs tig welding ideally
a very good friend of mine does any welding i need
he can weld steel, stainless steel cast iron bronze, copper ,brass and aluminium   :daumenhoch:
well you know where i am if you get stuck  B  :smiley6600:
Offline HUTCHMAN
Re: Fricko post
« Reply #20 on: January 05, 2012, 08:59 PM »
skyway67.....i think you've just become EVERYBODY'S new best friend.   :LolLolLolLol:
Re: Fricko post
« Reply #21 on: January 05, 2012, 11:47 PM »
 :LolLolLolLol:  true
so where abouts are you in the country
we might have to talk  ;)
skyway67
Re: Fricko post
« Reply #22 on: January 06, 2012, 08:21 PM »
i'm in worcestershire near the safari park and severn valley railway
as i said earlier in your thread a post like aluminium would drill fairly easy ........... is it 22.2 mm ?
also the seat post damage looks straight forward as long as the metals good
would the frame be powdered after ?  :)
Re: Fricko post
« Reply #23 on: January 06, 2012, 09:06 PM »
Your about 2h48mins away from me so a courier it would be
yes it alloy - most likely 22.2
yup tube top has two cuts (not by me) and done back it the day i think  - will just need a weld and then maybe another cut ?
yes being powdered up
there is one of the extra tubes that is missing a bit of welding ? and as it will be under powder, can your mate do that ? 1/4"
cheers B  ;)
skyway67
Re: Fricko post
« Reply #24 on: January 06, 2012, 09:37 PM »
no problem
the seat post would have to be drilled out first
then the tube prepped and welded up and have the expansion slot machined in after  :smiley6600:
