976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 19, 2026, 12:08 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Skyway Bearing Size??
Author Topic: Skyway Bearing Size??  (Read 6252 times)
« on: January 11, 2012, 09:23 PM »
Anyone know what size the bearings are on the front Skyway Tuff II, the old type, not alloy hub?? :daumenhoch:
Re: Skyway Bearing Size??
« Reply #1 on: January 12, 2012, 10:26 AM »
up
« Reply #2 on: January 12, 2012, 10:58 AM »
round small and shiney  :daumenhoch:
mattuknc
« Reply #3 on: January 12, 2012, 11:36 AM »
I have a set from the rebuild kits bendy was selling if you need some.  :daumenhoch:
« Reply #4 on: January 12, 2012, 12:11 PM »
Brilliant Matt, pm incoming. :daumenhoch:
« Reply #5 on: January 12, 2012, 07:55 PM »
I'm still looking for some of these guys, the loose ball type please lads. :daumenhoch:
« Reply #6 on: January 12, 2012, 08:07 PM »
Graham weigh will have some :daumenhoch:
« Reply #7 on: January 12, 2012, 08:59 PM »
True enough, i'm just being lazy. :daumenhoch:
« Reply #8 on: January 12, 2012, 09:43 PM »
so the bearing from my kits must be bigger ? lmk  ;)
« Reply #9 on: January 13, 2012, 08:14 AM »
i'm not sure tbh B, I bought an orphan Tuff cheap off the bay, it was cheap as there was some bearings missing, i'll just strip it down and measure one of the ones in it.
« Reply #10 on: January 13, 2012, 10:47 AM »
You might be able to just use a couple of my bearing cages ? pm with pic of hub  ;)
« Reply #11 on: January 13, 2012, 01:48 PM »
will do when i get home from work B, cheers. :daumenhoch:
« Reply #12 on: January 13, 2012, 08:31 PM »
Right B, here's a pic of the hub...
If it helps, the bearings are smaller than bottom bracket bearings and bigger than headst ones. ??? ::) :daumenhoch:
« Reply #13 on: January 13, 2012, 09:16 PM »
I think my cage bearing will fit with the shield on - couple of quid will get you 4 mate
« Reply #14 on: January 13, 2012, 09:29 PM »
I'll let you know tmrw night B, gonna try and get some in work tmrw first. Cheers Bud. :daumenhoch:
« Reply #15 on: January 14, 2012, 12:47 AM »
 ;) ok
mattuknc
« Reply #16 on: January 14, 2012, 05:00 PM »
Or I can still stick4 in the post to you?!?  :P
Offline bobbbbsy
« Reply #17 on: January 14, 2012, 09:19 PM »
1/4 inch mannnnnnnnnnnnn! just redid mine with
 http://www.ebay.co.uk/itm/370434088745'ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649#ht_1442wt_1025
a few days ago. even used the old cones as 1 would nt budge. they spin champion lad !
« Reply #18 on: January 15, 2012, 03:09 PM »
Cheers bobbbbsy son, just bought some loose bearings last night, they should be reet. :daumenhoch:
Did you split yours from the cages?
Offline bobbbbsy
« Reply #19 on: January 16, 2012, 10:49 AM »
i did nt no. they fitted fine and spin real good with a load of lithium grease(let the debate begin-lol) so i am happy..caged are just an easy alternative to loose bearings. loose bearing came out originally !  :10_2_12: :daumenhoch:
« Last Edit: January 16, 2012, 10:53 AM by bobbbbsy »
