976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 18, 2026, 02:20 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  suntour coaster brake
Author Topic: suntour coaster brake  (Read 2386 times)
kjilaja
« on: February 09, 2012, 08:56 PM »
just purchased one of these and need to know how to fit to a tuff2,do i need to buy alloy hubbed tuffs and change the centre or is there a way to put a coaster in my plastic middle tuffs?? if that makes sense any help appreciated,thanks..
Re: suntour coaster brake
« Reply #1 on: February 09, 2012, 09:03 PM »
Yes you need to get Alloy hub tuff, back or front & drill out the rivets & bolt it in, do you have the bolts ? if not I may have some spare  :daumenhoch:
Also take photo's of the rivets & post them on here before you drill them out, because you have to drill a certain side out  :)
snav69
« Reply #2 on: February 09, 2012, 09:04 PM »
Don't think you can just put a coaster into any tuffs  :-\ unless it's one of the complete Suntour ones that have the brake and flanges built together  ???
snav69
« Reply #3 on: February 09, 2012, 09:08 PM »
Is it one of these that you've bought  ???
 :coolsmiley:
« Reply #4 on: February 09, 2012, 09:19 PM »
You are right Paul, I assumed this was the type that kjilaja was referring to  ???  but good point  :daumenhoch:
kjilaja
« Reply #5 on: February 09, 2012, 09:25 PM »
the one in the pic looks the same as what i've just bought,what are my options with this?
snav69
« Reply #6 on: February 09, 2012, 09:30 PM »
You need an alloy hubbed tuff (front or rear) and drill the flanges off but be careful as Chris points out there's a right and wrong way of doing this  :daumenhoch:
Then the suntour one just slots in through the gap and twists in't place lining up the rivet holes  ;)
 :coolsmiley:
« Reply #7 on: February 09, 2012, 09:31 PM »
you cant put it into the tuffs you bought from me nick
they would have to be steel or alloy rear mate i reckon
« Reply #8 on: February 09, 2012, 09:31 PM »
 :coolsmiley:
Yes as Paul says, do you have the bolts with it  ???
Offline BrianP
« Reply #9 on: February 09, 2012, 09:36 PM »
I've an instruction sheet for one of the hubs shown above - give me an hour and i'll have it dug out, scanned, photobucketed and on here
Brian  :daumenhoch:
kjilaja
« Reply #10 on: February 09, 2012, 09:44 PM »
don't think it comes with bolts,won it on the bay today if anyone wants to look and see what i've got,whether it's the right one,sellers id hondadominator or search for suntour coaster brake... :)  i guess i now need to hunt a alloy hubbed tuff, orange black or white,should i post in the wanted section? :)thanks for your help so far always wanted a pedal back brake since being a nipper,was hoping i could put this on my orange streetbeat that i've just got of brummie,gonna go for a neil ruffell rep...
« Reply #11 on: February 09, 2012, 09:52 PM »
I will have a look for the bolts for you  :)
Offline BrianP
« Reply #12 on: February 09, 2012, 10:00 PM »
Here you go mate, info for when you need to drill out the heads of the rivets.
Instruction sheet off my first coaster brake, circa 1984/5 :)
Brian  :daumenhoch:
« Last Edit: February 09, 2012, 10:03 PM by brianp »
kjilaja
« Reply #13 on: February 09, 2012, 10:17 PM »
cheers brian,will be back when i've purchased a alloy tuff!!!! thanks :)
Offline BrianP
« Reply #14 on: February 11, 2012, 01:23 PM »
kjilaja
« Reply #15 on: February 12, 2012, 06:13 PM »
@wish id kept my ta... anyluck finding the bolts for the coaster brake mate,thanks
