976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 18, 2026, 06:07 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Kashimax Restro - still looks powdery (Blue with pictures)
Author Topic: Kashimax Restro - still looks powdery (Blue with pictures)  (Read 13181 times)
punkdSICO
« on: February 15, 2012, 04:45 PM »
Hi all
Ive raised this before but, still having problems with a Kashi restro.  Previously it was suggested that I try different dye (Dylon) which I have now just finished BUT it still looks like it has powder on it. Its been sanded down to 1200 grade and its smoother than a baby's butt..  With the smallest amount of water, it looks perfect.  Indeed, the second pic below (bottom of the pic) shows a finger print mark and even that amount of grease gets rid of the whiteness..
Any thoughts?  I was about to wipe it with a TINY amount of WD40 but open to better suggestions??
PS: the expert bloke on BurnerWorld said he will not touch blue Kashi's as they never turn out right.  So perhaps the above results are just epidemic of all blue Kashi's??
ta
Paul
Re: Kashimax Restro - still looks powdery (Blue with pictures)
« Reply #1 on: February 15, 2012, 05:03 PM »
i had a nos blue one that kept going like a powder on the surface.
i soaked it in gloss amourall from halfords.
done the trick and when it did start whitening a bit again a quick wipe over and it was sorted again.
worth a try.
monkian
« Reply #2 on: February 15, 2012, 05:04 PM »
If you're desperate you could try painting it. Shat did I just say that!!! :-\
At least it's not a set of Skyways. Plasti Kote Super in a satin finish maybe??
http://www.plasti-kote.co.uk/Product/pcode---4181
Just an idea :-X
« Reply #3 on: February 15, 2012, 06:07 PM »
carefully flame polish it with a blow torch, job done shiney shineey
« Reply #4 on: February 15, 2012, 06:19 PM »
t-cut or glass-cut followed by a polishing mop?
punkdSICO
« Reply #5 on: February 15, 2012, 06:59 PM »
Hey mate - I just tried baby wipes but they did not work.  Ill see if I can get hold of some window wipey things like your Amourall..
ta,
Paul
punkdSICO
« Reply #6 on: February 15, 2012, 07:02 PM »
You serious??   ???  Sounds a bit severe..  Besides, the saddle has a lovely surface; it sanded up lovely..  I just the whitening affect when dry..
ta,
Paul
punkdSICO
« Reply #7 on: February 15, 2012, 07:04 PM »
Hey mate - really dont fancy painting it.  As mentioned, the finish is really lovely and when wet, it looks totally MINT!  Its just this darn whitening..   :(
Off to my workshop to try some of my special polish, ai!!    :coolsmiley:
Paul
mark 2
« Reply #8 on: February 15, 2012, 07:20 PM »
I had this problem, I wrapped it in 200g of lean back bacon, left it in the fridge for 48hrs. Try it.
mark 2
« Reply #9 on: February 15, 2012, 07:21 PM »
I'll just add it did fook all.
Offline Discostu
  • Two's Company
« Reply #10 on: February 15, 2012, 07:45 PM »
Why not try a bit of back to black spray from halfords or your local garage? It was always good at giving a sheen to black plastic bumpers that had gone white. Just give it a spray and a wipe every so often.  :daumenhoch:
« Reply #11 on: February 15, 2012, 07:48 PM »
you can get that armorall in a matt finish that might look better than shiny
« Reply #12 on: February 15, 2012, 07:50 PM »
Blue Tcut?
punkdSICO
« Reply #13 on: February 15, 2012, 07:52 PM »
Despite several attempts, this did feck all (although my Kashi does now have clamydia)..
I also tried Window Lean (like the Amourall suggestion).
I then tried my polish wheel but instantly stopped as the dark impregnated polish started to show on the seat.
Also tried some "All Metal Shine" and this looked great for 20 mins this has also now started to dry with visible whitening..
Sucks..
Paul
rad_pitt
« Reply #14 on: February 15, 2012, 08:00 PM »
As mad as it sounds - the blow torch is probably your best bet. I've seen it done on other blue seats.
rad_pitt
« Reply #15 on: February 15, 2012, 08:05 PM »
Before
After
Offline jT Racing
  • i like bikes. :/
« Reply #16 on: February 15, 2012, 08:59 PM »
ding dong
« Reply #17 on: February 15, 2012, 09:03 PM »
Right the trouble here is with the sanding process
 the colour was added when the seat was made - when finished, it looks a solid colour and has a polished surface for a shine/solid colour look
if now you take sand paper and rub it over, this will leave small lines - small flakes/scratches will lose the solid colour and turn it a white/clear with each mark
now if you sand the seat with different grades, it will look whitish - this is what you have - now by putting water or grease on it, it will join where the sanded lines/flakes have lifted, making it look solid again
adding heat will join the flakes/lines together and making it look solid - there will be a point where it heats up and becomes smooth, as the heat melts it it will look shinny
dying it with dylon will only coat/cover the out side - if it has small lines/flakes they will not dye so well and will still look whitish
how long did you leave it in for ?
sanding it down to a smooth or very flat finish might look better and dye better, but heat will give it a more solid colour look after it has been sanded like that
you could also try another way after heating up - it will have a smooth look when heated, but you could try rolling a pattern on to it - the original seat has a slight texture to it - rolling some thing like sand paper over it or some thing similar might give it back it's pattern again ?
punkdSICO
« Reply #18 on: February 15, 2012, 09:05 PM »
Cool..  So, I presume the Before/After pics are using the blow torch method??  If so, very impressive results and the before looks exactly like mine..
Regarding a blow torch, I dont own one so could I just carefully use the gas rings on my oven?
"I'll just add it did fook all."  - yeah, I laughed at that aswell :)
ta all..
Paul
punkdSICO
« Reply #19 on: February 15, 2012, 09:09 PM »
Prob about 3+ hours using boiling water and lots of salt.  I dont think the problem/solution is with the dying
Cool idea..  Not sure I will try the pattern effect as sounds tricky but, defo gunna try the heating up (assuming it is okay to use a gas oven ring instead..).
Some great help in this thread - big thanks..
Paul
« Reply #20 on: February 15, 2012, 09:32 PM »
Bendy is right, its the microfine scratches from sanding that make it look powdery. The sanding marks are visible in your pics. I have seen flame polishing done a few times and it does give great results, if you know what you are doing. I would be tempted to get some plastic polish and give it a bloody good go with that first.
monkian
« Reply #21 on: February 15, 2012, 09:35 PM »
You can use Autosol on plastic :)
« Reply #22 on: February 15, 2012, 09:52 PM »
trouble with the gas rings is you can't see the change and what is happerning
you could see if a hair dyer will do any thing - a heat gun would work but being carefull at it
polishing will work but you will have to work at it  ;)
punkdSICO
« Reply #23 on: February 17, 2012, 12:22 PM »
Yeah, I just found this out :)  Tried the oven on a very small area and like you say, it went from doing nothing to small bubbles that now need to be re-sanded..   >:(
I'll try a hairdryer next..
ta,
Paul
« Reply #24 on: February 17, 2012, 01:13 PM »
what window lean did you use.
the amourall i was talking about is for making your tyres shine etc on ya car.
i've just red about using a heat gun on vw bumpers. puts the color back in them after they have whitened so might be worth a go.
