976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 17, 2026, 02:05 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Have i got the wrong caliper???
Author Topic: Have i got the wrong caliper???  (Read 3348 times)
lusky75
« on: April 05, 2012, 09:07 PM »
Evening everyone.
I have a problem.. i got my rear caliper today, but it does not fit???
I think its a front, or something is missing :(
Check pics out.
Here it is in forks, seems short here aswell???
Any help please.
Thanks. :)
Re: Have i got the wrong caliper???
« Reply #1 on: April 05, 2012, 09:12 PM »
No
It's because you have a flat brake bridge apposed to a 'tube' brake bridge !
Turn the washers around so they are light a 69 position to make a thick washer  :daumenhoch:
lusky75
« Reply #2 on: April 05, 2012, 09:15 PM »
Did that . just looked a bit high ::)
Thanks.
« Reply #3 on: April 05, 2012, 09:17 PM »
Just use some normal washers in that case  :daumenhoch:
snav69
« Reply #4 on: April 05, 2012, 09:44 PM »
I have a spindle for a flat bridge on some DC calipers here  :daumenhoch:
Swap you if yours is a DC one  :angel:
Will get pics tomorrow  ;)
snav69
« Reply #5 on: April 05, 2012, 09:47 PM »
Just seen in another thread that these are the new mx1000's  :buck2:
Sorry mate but i wanted an old one  :daumenhoch:
« Reply #6 on: April 05, 2012, 10:37 PM »
you will be better using a dia compe 1020 caliper for a cali, the brake blocks might not quite reach the rim using that
« Reply #7 on: April 06, 2012, 12:25 AM »
is it not just that he has the front on the rear and the rear on the front  ???
right about the wwashers but it looks as though it all the wrong way around ?
« Reply #8 on: April 06, 2012, 12:52 AM »
I was just thinking the same thing there Bendy.  :daumenhoch:
« Reply #9 on: April 06, 2012, 01:08 AM »
hard to see whats in front mate but just looks that way to me  :D ;D ???
ozone
« Reply #10 on: April 06, 2012, 08:24 AM »
Definitely a front brake.  If it came from Alan's send it back and tell them to give you the correct one.  You can buy the spindles on ebay BTW.  (not DC but it doesn't matter on those new reissued brakes)
lusky75
« Reply #11 on: April 06, 2012, 10:05 AM »
I only bought a rear one guys. sick as!
Dont know whats going on??
Might just put it on the front like, didn't really want to.
snav69
« Reply #12 on: April 06, 2012, 10:21 AM »
It's a rear mate, It just hasn't got the washers on it  :daumenhoch:
If you put the washers on it would fit perfect on a round brake bridge  ;)
 :coolsmiley:
lusky75
« Reply #13 on: April 06, 2012, 06:36 PM »
Here is a pic of it fitted with the round bar washers back to back ... if ya know what i mean ???
Still seems a bit high off the frame, is this normal.
Could anyone take some pics of theres??
Thanks.
« Last Edit: April 06, 2012, 06:38 PM by lusky75 »
Rodgy1970
« Reply #14 on: April 06, 2012, 07:14 PM »
Put the washers on the same side as the nut   :daumenhoch:
« Last Edit: April 06, 2012, 07:19 PM by rodriguez »
« Reply #15 on: April 06, 2012, 08:40 PM »
yup try that above
see what they look like the other way around
i was under the thought thaqt the longer front bolt had to go through the fork tube and that was why it was longer - the rear only had to go through the round brake bridge or flat bridge and so that was the shorter one  ???
as for look different from rear to front, i thought there was none bar the sizr of the bolt it's self ?
