976342 Posts in 138998 Topics by 6442 Members - Latest Member: Onlystans August 18, 2026, 11:52 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Wheel building advice/words of wisdom.
Author Topic: Wheel building advice/words of wisdom.  (Read 2178 times)
GaryN
« on: April 13, 2012, 10:24 PM »
Gents,
After some ebay wins it looks like I might have a go at building a wheel I must be  :crazy2:, it will be a rear wheel.
First up, how do I find out what spoke length to get and should I go for plain or butted spokes, and what pattern is good for a strong build?
What about spoke keys, what are good and will I need any other special tools?
Next, who has built their own wheels and how did it go?
Finally what words of wheel building wisdom/advice do you have for me?
Thanks in advance for your assistance.
Re: Wheel building advice/words of wisdom.
« Reply #1 on: April 13, 2012, 10:28 PM »
save your sanity. . . get someone else to do it for you!!!
GaryN
« Reply #2 on: April 13, 2012, 10:31 PM »
Unfortunately I fear that it is too late for that  :LolLolLolLol:
Hellcat
« Reply #3 on: April 13, 2012, 10:35 PM »
I don't really know anything about this, (my bro's a long term 'proper bike racer / sometime racing cyclist', I've seen a few rims & hubs over the years).
Could you not measure / copy a pattern off an existing wheel?
Whenever I've seen wheel builders they've always got those fork-like clamps to build in, but sure you could use your F&F.
If it all goes wrong then shops only charge £10 (+ spokes) for a build or truing, so what the's worst that could happen?
Offline kuwahero
    • Western Titans
« Reply #4 on: April 13, 2012, 10:38 PM »
Offline Munnyella
« Reply #5 on: April 13, 2012, 10:40 PM »
Its a piece of pi$$, google is your friend, so much info, once you have the right spokes, whats the worst can happen?
MM
Offline bigfatolly
« Reply #6 on: April 13, 2012, 10:50 PM »
If you have the right size spokes its pretty easy i did my first set a few weeks ago,truing up is the hard part. :daumenhoch:
GaryN
« Reply #7 on: April 13, 2012, 10:54 PM »
Spoke length calculating
http://www.radbmx.co.uk/forum/index.php'topic=136816.0
Sweet, that's really helpful. I will get everything measured up once I have the bits in my hand.
GaryN
« Reply #8 on: April 13, 2012, 10:55 PM »
Fortunately I do have access to a wheel truing stand, although I have only ever used it to true wheels.
« Reply #9 on: April 13, 2012, 11:19 PM »
Well I am glad somebody is reading the hard work put into creating the stickies, funny enough I also did this one...
http://www.radbmx.co.uk/forum/index.php'topic=1344.0
GaryN
« Reply #10 on: April 14, 2012, 01:14 AM »
I had discovered the stidds wheel build how to but for some reason thought that it ended at the last picture in the series, what a numpty  ::)
Cheers guys.
Offline john4130
« Reply #11 on: April 14, 2012, 07:10 AM »
one of the main things when building a wheel is making sure all the spoke nipples get the same amount of turns, if you have a wheel to copy the lacing pattern then build it with all the spokes loose, then get a spare spoke and make one of these.
leave about 3 threads sticking out and then crimp the nipple to the spoke. then go round the wheel with the tool tightening each spoke until the tool bottoms out like this.
the spokes nipples will all be at the same depth then get a spoke key and go round the wheel giving each spoke one full turn. keep doing this until there's a good tension in the wheel, then it will only need a little bit of truing.
GaryN
« Reply #12 on: April 14, 2012, 11:23 AM »
@ john4130, now that is a sweet tip  :4_17_5:
I will use that for sure, simple yet effective.
Offline Dannywhac
  • return of the whac
« Reply #13 on: April 14, 2012, 12:26 PM »
Yeah - John's tip saves the pain in the rear you can get when your building your wheel and some spokes slacken off whilst your moving the wheel to spoke up.
Also fella, if you get stuck at all give me a shout as I do my own and I'm just up the road from you in Bury  :daumenhoch:
nosepickben
« Reply #14 on: April 14, 2012, 12:52 PM »
http://www.gsportbmx.co.uk/custom/wheel_build/wheels.html
Follow this and you can't go wrong. If it's all new parts, the wheel should work out straight and true. If not fixing it is dead easy. mount on a frame & view from above, tighten the 2 or 3 spokes on the correct side of the hub you need to pull towards by one turn at a time & slacken off the ones in between (ie the other side hub flange) by half a turn. Works for me.
Offline Dannywhac
« Reply #15 on: April 14, 2012, 01:01 PM »
Don't forget though that George in that wheel build guide does a tuck pattern on the spokes to help stop grind damage  :daumenhoch:
