976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 16, 2026, 06:48 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Gearing Q:
Author Topic: Gearing Q:  (Read 1969 times)
Gearing Q:
« on: April 15, 2012, 11:49 AM »
Just having a look at some of the bits i have for a build and have a snow flake chain ring of 44t which i want to use and also found a suntour 17t = now is that gonna make me pedal like a Muppet
i try and run a 44/16 and find it good - then on another ride i have and that is 40/16 harder to keep up but great for a quick burst of speed - rides alright
so where will the 44/17 sit ?
cheers B  ;)
Rodgy1970
Re: Gearing Q:
« Reply #1 on: April 15, 2012, 11:59 AM »
http://www.bikecalc.com/gear_ratios
Harder to pedal than 40/16 not as hard as 44/16.
Offline Jon The Bassist
Re: Gearing Q:
« Reply #2 on: April 15, 2012, 12:00 PM »
Dr Jon in the house.
Your 44/17 will feel slightly higher than the 40/16, more like a 41/16.
If you're gonna ride this much get a 16 tooth freewheel :daumenhoch:
Re: Gearing Q:
« Reply #3 on: April 15, 2012, 12:12 PM »
Cheers guys - it's going on a Team goose i'm doing and the old snow flake is some thing i want to keep - the suntour is a spare sitting around - the bike will most likely only be ridden on such things like one london ride and a couple of shows ~ so i guess if it is sitting in the middle it should be alright
the 40/16 on the london ride on the silverfox was alright but better for cutting down the streets and not long roads
well if nothing comes up i will try it   ;D
cheers B  ;)
Offline Twesnik
Re: Gearing Q:
« Reply #4 on: April 15, 2012, 12:16 PM »
Donīt forget the lenght off the crank-armīs!
Re: Gearing Q:
« Reply #5 on: April 15, 2012, 12:21 PM »
more like me little legs  :-[
175's 1pc
nosepickben
Re: Gearing Q:
« Reply #6 on: April 15, 2012, 12:58 PM »
As a rough guide, going 1 tooth higher at the back will feel like going down 2 and a half on the front.
