976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 16, 2026, 02:40 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Chopping bar width. Easiest & cheapest...
Author Topic: Chopping bar width. Easiest & cheapest...  (Read 1642 times)
Hellcat
« on: April 22, 2012, 08:33 PM »
What do I need?
Hacksaw? (& a vice?)
Or will it be easier / cheaper to take it to a bodyshop / metal workers to do it 5 mins? ;)
Dan
Re: Chopping bar width. Easiest & cheapest...
« Reply #1 on: April 22, 2012, 08:37 PM »
what width are you cutting down to?
Offline Betty
« Reply #2 on: April 22, 2012, 08:43 PM »
Leave the bars on the bike and use a hacksaw, takes no time at all
Top tip: Take the grips off   :daumenhoch:
2 minutes turkish...
« Reply #3 on: April 22, 2012, 08:44 PM »
what bars are they
maybe someone with chopped bars after a trade etc
Hellcat
« Reply #4 on: April 22, 2012, 09:05 PM »
Bars are Fly in metallic orange 28 inch, looking to cut 1 inch off.
They a bit scuffed up, but very light.
 :daumenhoch: Betty, can see that would work.
Offline Betty
« Reply #5 on: April 22, 2012, 09:55 PM »
Try them before you give them the chop, 28" wide is spot on  :daumenhoch:
Hellcat
« Reply #6 on: April 22, 2012, 09:58 PM »
Ok will do. Guess I have to fit them before hacksawing. :daumenhoch:
« Reply #7 on: April 22, 2012, 10:02 PM »
Dont cut em bud, you will regret it  :daumenhoch:
Hellcat
« Reply #8 on: April 22, 2012, 10:17 PM »
Ok. Will def swap & give em a go before cutting. :daumenhoch:
Offline Gary72
« Reply #9 on: April 23, 2012, 08:18 PM »
I've used a plumbers pipe cutter from B&Q a few times. Takes abit longer but I think it gives a neater finish. Only problem I've come across is that you have to file the inner part of the tube where the bar end goes.
