976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 16, 2026, 11:50 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Odd seatpost clamp size
Author Topic: Odd seatpost clamp size  (Read 2638 times)
Offline Devilock
« on: April 24, 2012, 03:51 PM »
Can anyone suggest a generous size seatpost clamp (apart from a DC twin or hinge) as my Torker seatpost tube is just a little bigger than standard...?!
Re: Odd seatpost clamp size
« Reply #1 on: April 24, 2012, 04:12 PM »
burner one  ;) 25. ?
Offline Devilock
« Reply #2 on: April 24, 2012, 04:54 PM »
burner one  ;) 25. ?
Not sure...I know its not due to any thick paint as its chrome. So what are the options...??  :-\
Im not using a Raleigh  :yahoo_silent:  :D
« Reply #3 on: April 24, 2012, 05:16 PM »
well some of the tange ones are bigger - you got nothing to mesure it with ?
Offline Devilock
« Reply #4 on: April 24, 2012, 05:27 PM »
Tried a Tange & its too small! Not at home so Ill measure later... Ill probably just buy a twin bolt!
Also, my DC hinged doesn't really fit correctly either...!!  :wtf:
« Reply #5 on: April 24, 2012, 06:39 PM »
have seen a couple of post that are bigger - and as you know mk 1 burners are the same
give it a measure and we can see what we can dig out for you  ;)
sid1972
« Reply #6 on: April 24, 2012, 06:56 PM »
Gaz, had a oversized suntour clamp in gold for sale not long back, i am sure that was burner size. But its the standard suntour just bigger.  ;)
« Reply #7 on: April 24, 2012, 07:06 PM »
yer seem to remember there were two sizes -larger fitted burners as did the tange  ???
sid1972
« Reply #8 on: April 24, 2012, 07:28 PM »
Here you go - I sold it him for more than he is asking anyway, not sure if it sold though drop poolysheriff a pm.
Offline Devilock
« Reply #9 on: April 24, 2012, 08:15 PM »
True...Gaz has got everything...!
Ill measure it...
& the seat tube...!!!
Offline Devilock
« Reply #10 on: April 25, 2012, 04:12 PM »
Right, Ive measured the seatpost tube on the Torker & it has a circumference of 81.5cm. Measured my TA & thats 80cm... Why the fúck would it be 1.5cm bigger??!!?!? Stupid...
Offline Devilock
« Reply #11 on: April 25, 2012, 04:14 PM »
Oh, I also measured a Tange seatpost tube & that is 80cm...
« Reply #12 on: April 25, 2012, 04:18 PM »
Thickness of the paint/powder could easily account for that  :-\ .
Offline Devilock
« Reply #13 on: April 25, 2012, 04:43 PM »
Ah, no because all the frames measured are chrome...
Offline Devilock
« Reply #14 on: April 25, 2012, 04:43 PM »
All original chrome too...
« Reply #15 on: April 25, 2012, 09:12 PM »
ok so the seat clamp doesn't go on
does the seat post you have slide in smooth or tight ?
have you tried a couple of different post in there ?
you know the 1.5 mm could be a seat post that was slightly larger fitted and has opened up the seat tube top where the split is ?
maybe measure the thickness of the metal on a couple of your other bmx's to see what they are like ?
you may find it's thicker ?
you may also find that with the right seat post you can squeeze together the seat post about 1.5 mm and it will allow a good clamp on there ?
HEYWOOD BMX
« Reply #16 on: April 26, 2012, 09:51 AM »
Does a newschool clamp fit? If so,it`ll be a 28.6mm (1 1/8) internal diameter.
« Reply #17 on: April 26, 2012, 10:39 AM »
Right:
80MM circumference  = 25.4mm Diameter
81.5MM circumference = 25.9mm Diameter
http://www.rkm.com.au/calculators/calculator-circle-sphere.html
I would suggest that it's MM not CM as it would have to be a fooking huge frame  :LolLolLolLol:
That level of difference is tiny, less than half a millimetre so most likely within a manufacturing tolerance.  Try opening up the seat post clamp a little when you put it on or sand down the inside of the clamp with wet & dry to remove some of the material.  Obviously opening the clamp up a little with a wooden wedge is the least damaging to the clamp!
