976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 16, 2026, 09:05 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  skyway alloy hub rivets
Author Topic: skyway alloy hub rivets  (Read 1510 times)
kjilaja
« on: April 29, 2012, 03:31 PM »
hi,i have a alloy hubbed skyway with coaster but it's got screws and bolts which i don't want,is it possible to get rivets for these and how easy are they to put in(do you need a rivet gun?)or does anyone know of someone who can rivet them for me,thanks in advance.... :daumenhoch:
Re: skyway alloy hub rivets
« Reply #1 on: April 29, 2012, 03:43 PM »
Are they UK made ones? If so the hub is correct.
« Reply #2 on: April 29, 2012, 03:52 PM »
Aside from Skyway in the States, the only other Skyway Rivet machine that works is in Australia.  BUT there have been people who have been able to make up the machine rivets at a machine shop and have them fitted that look just like the OG ones so it can be done.
kjilaja
« Reply #3 on: April 29, 2012, 03:59 PM »
not sure if a uk version,how do you tell?it has a serial number in white stamped on the side..will the screw and bolts hold out,they just seemed a bit flimsy :-\
« Reply #4 on: April 29, 2012, 10:53 PM »
Just buy the appropriate sized hex headed bolt and grind it to a rivet shape on a bench grinder 5 mins tops for each rivet.
then ask Frankentuff what glue he uses and glue them in  ;)  :daumenhoch:
« Reply #5 on: April 30, 2012, 02:01 PM »
Using the Search feature on the website I found this old thread from a while back  ;)
http://www.radbmx.co.uk/forum/index.php'topic=90346.msg900819;topicseen#msg900819
