976294 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 15, 2026, 03:31 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  restoring mx1000's
Author Topic: restoring mx1000's  (Read 1638 times)
Offline benno
restoring mx1000's
« on: May 22, 2012, 10:22 PM »
Hi guys just stripped and painted my mx 1000's and put a new decal over the stamped dia compe bit ,
BUT now i want to paint in the MX bit anyone got any ideas the best way or is it a case of tiny brush and a steady hand
or a blue sharpie pen or the like  :)
cheers Benno
It comes out of the ground!
sid1972
Re: restoring mx1000's
« Reply #1 on: May 22, 2012, 10:25 PM »
I use a paint pen, any that goes over the edges can be rubbed off. I then use clear varnish with a fine brush to seal it.
Offline benno
« Reply #2 on: May 22, 2012, 10:40 PM »
yeah gonna have a look at what size tips i can get sharpie's in ,
i was planning on laquering them after so that will seal it in
cheers Benno
Offline bobbbbsy
« Reply #3 on: May 22, 2012, 10:46 PM »
 :4_17_5:
sid1972
« Reply #4 on: May 22, 2012, 10:48 PM »
your better off with a large flat nib and paint over the surface - rub the excess off when its been on a few minutes. Use the flat edge of a knife wrapped in a tight cloth. This leaves the paint in the recess.
hope that make sense.
« Reply #5 on: May 22, 2012, 11:02 PM »
dont del do the stickers for these.
sure i had some off him in white.
« Reply #6 on: May 22, 2012, 11:17 PM »
you can get uni posca paint pens off ebay with a 0.3mm nib that does the job..tried and tested :daumenhoch:
