976344 Posts in 138998 Topics by 6443 Members - Latest Member: BMX1970 September 03, 2026, 03:48 PM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  Haro backtrail crank, possible problem.
Author Topic: Haro backtrail crank, possible problem.  (Read 11676 times)
Offline sparkysx
« on: June 03, 2012, 01:28 AM »
I have put these cranks on this Haro Backtrail, and the locating tag that goes through the chainwheel, only goes into it by about 1mm or so. The bottom bracket isn't the sealed type, and so the chainwheel is slightly further away from the cranks than it would be if it did have sealed bearings.
Is this a problem? could I be pedaling fast one day, and it slip out? and would a sealed BB sort this problem out?
Cheers!
Re: Haro backtrail crank, possible problem.
« Reply #1 on: June 03, 2012, 11:32 AM »
I wouldn't trust that mate, no.
Treat yourself to a sealed BB, that'll fettle it and be nicer to ride too  :daumenhoch:
Offline Jon The Bassist
« Reply #2 on: June 03, 2012, 11:46 AM »
Looks like the Tophat washer isn't right for that crank spacing, try a diffferent one perhaps.
« Reply #3 on: June 03, 2012, 11:54 AM »
i don't think changing the BB will make a bit of diference  :-\  other than being much smoother and longer lasting.
I'm with John, the problem is the sprocket is too far away from the crank arm, either a new top hat washer, or grind that one down a little so the sprocket goes right up to the crank arm.
Offline sparkysx
« Reply #4 on: June 03, 2012, 01:08 PM »
Im talking about replacing the bottom bracket and spindle for a sealed one, this one has no top hat washer
Offline Munnyella
« Reply #5 on: June 03, 2012, 01:27 PM »
To be honest, I'd replace the entire crank, they are pretty rubbish cranks anyway, I have a knackered set in the shed, I use them as hammers!!
BMX city do a full job with sealed BB for £35 I think. Not the best, but good for the money and It'll have a chainring bolt fixing not a peg.
Just a thought, thats all!
MM
« Reply #6 on: June 03, 2012, 01:34 PM »
Surely his problem is all down to the unsealed BB and the way it all goes together?
A sealed bb will allow him to fiddle around with tophats and sort it out?
Offline sparkysx
« Reply #7 on: June 03, 2012, 01:45 PM »
Yeah its all down to the unsealed bb. I would like to keep the cranks as they are chrome.
Offline sparkysx
« Reply #8 on: June 03, 2012, 01:53 PM »
£35 may be worth it if it included the bearings and spindle and all the washers. Counterfeit do it for this price.
Offline Dannywhac
  • return of the whac
« Reply #9 on: June 03, 2012, 04:30 PM »
Just take the drive side crank arm off, and turn the top-hat washer round (so the bit that sticks out on it is on the inside of the sprocket). Then it'll fit in the hole.
Offline Discostu
  • Two's Company
« Reply #10 on: June 03, 2012, 06:54 PM »
Yeah Danny is right. The top hat washer is the wrong way round.  :daumenhoch:
Offline bobbbbsy
« Reply #11 on: June 03, 2012, 07:08 PM »
the set from bmx city are counterfeit. this dos nt look right to me either ! take it apart !  :daumenhoch:
Offline sparkysx
« Reply #12 on: June 03, 2012, 08:37 PM »
It doesn't have a top hat washer
« Reply #13 on: June 03, 2012, 09:10 PM »
Sparky, I don't think they're following you bud.... What they're seeing as a top hat is actually part of the spindle yes?
Offline Dannywhac
« Reply #14 on: June 03, 2012, 09:18 PM »
Ah - sh1t - it's not a sealed is it  ;D Teach me not to read.
Offline sparkysx
« Reply #15 on: June 03, 2012, 09:39 PM »
Yeah it's part of the spindle, that's why I thought that a sealed BB would sort it.
« Reply #16 on: June 03, 2012, 09:47 PM »
And you'd be right  :daumenhoch:
What's the deal with the axle at the ends, 8 spline, square, 48 spline?
Offline sparkysx
« Reply #17 on: June 03, 2012, 11:09 PM »
8 spline, the crank arms are off a 2009 Freestyler.
« Reply #18 on: June 03, 2012, 11:20 PM »
Ok, Stodgy has those axles on the shelf I believe.
Cheap DiamondBack USA sealed BB  from ebay for about £14 and you're in business.
Offline oldtired
  • Dirty Old Man
« Reply #19 on: June 04, 2012, 11:58 AM »
follow the advice of the Munny  :daumenhoch:   £35 squids you cant go wrong plus you get free pedals  and   bb  :daumenhoch:
« Reply #20 on: June 04, 2012, 01:06 PM »
Yep, looks like an unbeatable deal.
Don't even use the new arms, your existing chrome ones will go straight on.
you could then sell your old unsealed axle & BB with the new black arms and get some of your money back.
Can't go wrong.
http://www.bmxcity.co.uk/counterfiit-cranks-and-pedals-deal-p-1130.html?cPath=19_23
Offline Discostu
  • Two's Company
« Reply #21 on: June 04, 2012, 06:09 PM »
Right I'm finding this hard to believe.
1- remove crank spindle and chainring.
2- fit only the spindle and bearings into the bottom bracket.
3- fit the chainring with a tophat washer on the inside onto the spindle
4- now fit the crank arm locating the pin into the chainring.
You don't need to buy anything!!!   :daumenhoch:
Offline Dannywhac
« Reply #22 on: June 04, 2012, 08:17 PM »
It's a threaded unsealed axle Stu - the tophat washer parts built in, so when you install the sprocket you've got to put it over the entire axle, then a threaded nut/bearing race holds the sprocket in position, same as a 1-piece crank. You can't just take off the drive side crank arm and change the sprocket on these fella.
Offline sparkysx
« Reply #23 on: June 04, 2012, 09:40 PM »
Lol
Offline Munnyella
« Reply #24 on: June 04, 2012, 10:20 PM »
Oh yeah, i forgot they come with pedals too!!!
MM
