976292 Posts in 138996 Topics by 6428 Members - Latest Member: Homebrewhero June 14, 2026, 10:17 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Metal to metal glue
Author Topic: Metal to metal glue  (Read 2196 times)
Clean
Metal to metal glue
« on: June 27, 2012, 02:12 PM »
RADsters,
I have a Bottom Bracket Ball Bearing rattling up and down the downtube of my current build (ask Spen for details); you can imagine it is slightly annoying.  :knuppel2:
My plan is to use metal glue squeezed through the little hole in the BB Shell that the bearing sneaked (euphemism) through to glue the pesky little mo-fo to the inside of the downtube / shell.  8)
The glue can't be too viscous - such as a paste - as I plan to inject it through the hole (5-7mm diameter, I would say) using a syringe. I am hoping a big dollop will set up with the little bugger secured within.  ;)
I am currently considering Evo-Stik Liquid Metal or Araldite Rapid Steel; any thoughts?  :-\
What is the best metal glue for this job?  :coolsmiley:
Thanks,
Clean.
Offline Peter J
  • I have issues
Re: Metal to metal glue
« Reply #1 on: June 27, 2012, 02:31 PM »
how about waxoyl  ???
« Reply #2 on: June 27, 2012, 03:09 PM »
I like the rattle Rich. It wil cover up the other rattles from all the loose nuts amd bolts when you've finished building it with your Fischer Price tools..... ;-D
Why not just squeeze a bath sealant into it? Bring it back round and i'll sort it for you mate....
Clean
« Reply #3 on: June 27, 2012, 03:14 PM »
 :yahoo_silent:
Bath sealant; now that's a thought.....  :daumenhoch:
Offline john4130
« Reply #4 on: June 27, 2012, 05:08 PM »
try a magnet over the hole and give the frame a rattle. it worked for me in the past.  :daumenhoch:
« Reply #5 on: June 28, 2012, 09:03 PM »
magnet  ???
« Reply #6 on: June 28, 2012, 09:10 PM »
Squirt some expanding foam in the tube.
« Reply #7 on: June 28, 2012, 09:38 PM »
Clean
« Reply #8 on: July 07, 2012, 05:08 PM »
For anyone interested, common or garden Super Glue did the trick.  ;)
Frame is now rattle free!  :daumenhoch:
Offline bobbbbsy
« Reply #9 on: July 07, 2012, 05:14 PM »
they always come out.. you did nt shake the fuker enough !!  :tickedoff:
