976342 Posts in 138998 Topics by 6442 Members - Latest Member: Onlystans August 15, 2026, 01:23 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Dying Pads, does it work? - PIC OF PAD NOW ADDED
Author Topic: Dying Pads, does it work? - PIC OF PAD NOW ADDED  (Read 1830 times)
« on: June 29, 2012, 05:48 PM »
Got an Old Black Mongoose Frame Pad that has faded, if I dyed the pad would the print turn black as well.
Any ideas?
« Last Edit: June 30, 2012, 10:43 AM by BMX1973 »
Offline region11
Re: Dying Pads - does it work
« Reply #1 on: June 29, 2012, 06:36 PM »
I've dyed an old skyway pad and an old zap pad and my experience was that print is affected by the dye.
Neil
« Reply #2 on: June 29, 2012, 06:54 PM »
I thought that might be the case. :(
I might try a permanant marker and avoid the wording.  :-\
« Reply #3 on: June 29, 2012, 07:24 PM »
I had some faded MT Racing Black pads ~ faded to brown on one side - white writing
dyed them black and the pads went nice and black but the white writing went to grey ! but it match the grips so worked out for me  ;)
« Reply #4 on: June 29, 2012, 07:49 PM »
could you not paint artists masking fluid over writing and then peel off afterwards
lk_97
« Reply #5 on: June 29, 2012, 08:12 PM »
Fabric pen might work?
« Reply #6 on: June 29, 2012, 10:23 PM »
Hmmm never thought of that  :-\ has anybody tried this.
« Reply #7 on: June 29, 2012, 10:47 PM »
Ive never seen anything good ever done with a fabric pen, and it works by soaking int othe fabric, on the pads the lettering will be vinyl, so a fabric pen wouldnt work, as its not writing on fabric, its over vinyl. and the pads are nylon, not an absorbant material that the pen would adhere to
I stand by my masking fluid idea, if you dont know what it is, then basically its like a liquid latex, you could paint over the top of the design, put the pads in for dying, then the masking fluid peels off like a rubber coating. It cant harm the vinyl as its normally used to go over the top of various different paints, and then removed afterwards to leave sharp edges on oil paints etc
https://www.google.co.uk/search?q=artists+masking+fluid&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-GB:official&client=firefox-a#q=artists+masking+fluid&hl=en&safe=off&client=firefox-a&hs=YGk&rls=org.mozilla:en-GB:official&prmd=imvns&source=lnms&tbm=shop&sa=X&psj=1&ei=yiLuT53eIcLF8gOgpa2VDQ&ved=0CEQQ_AUoBQ&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&fp=1deb3a27a4d9b1ab&biw=1366&bih=602
« Last Edit: June 29, 2012, 10:49 PM by Jaymz »
Offline john4130
« Reply #8 on: June 30, 2012, 09:20 AM »
i ruined a set of pads by dying them.  :tickedoff:
« Reply #9 on: June 30, 2012, 10:34 AM »
Thanks "Jaymz" I might give it a go.  Would it have to be used on both sides of the pad, as would'nt the dye soak through from the back? :-\ Anyone on here that can do this.  :-[ Dont want to ruin a semi-decent pad!
« Last Edit: June 30, 2012, 10:42 AM by BMX1973 »
