976341 Posts in 138998 Topics by 6442 Members - Latest Member: Onlystans August 15, 2026, 03:36 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Cheap fix for a worn Profile crank arm?
Author Topic: Cheap fix for a worn Profile crank arm?  (Read 1155 times)
Offline Jon The Bassist
« on: July 14, 2012, 11:31 AM »
My left Profile crank arm has quite a bit of wear on the splines and is flopping about a bit  :'(
I've tried swapping everything around every which way but it won't cure it.
I have to race tomorrow - does anyone have a way to bodge it just for tomorrow?
Offline Betty
Re: Cheap fix for a worn Profile crank arm?
« Reply #1 on: July 14, 2012, 11:42 AM »
Profile wobble   :'(
Time for new cranks if the splines on the arms are worn
As a temp fix give the splines on the spindle a bit of a bashing with a hammer so the arms fit tight again
2 minutes turkish...
« Reply #2 on: July 14, 2012, 11:47 AM »
Profile wobble   :'(
Cheers Mark, hopefully that'll get me through tomorrow  :daumenhoch:
« Reply #3 on: July 14, 2012, 01:51 PM »
you could mess up the rest of the cranks on all the other riders bikes - then you all stand the same chance with wobbly cranks  :daumenhoch:
bof
« Reply #4 on: July 14, 2012, 01:53 PM »
Jon I have a set of dk chopstick arms if you are interested cheap as chips  :)
« Reply #5 on: July 14, 2012, 01:58 PM »
Cheers Bof, another RADster might have some Profiles for me, I'll speak to you if I don't get sorted :daumenhoch:
