976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 26, 2026, 04:10 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Profile crank tool - where can I buy and what are the benefits
Author Topic: Profile crank tool - where can I buy and what are the benefits  (Read 4091 times)
Offline jimwise68
Anyone know where I can buy one in Central London?
« Last Edit: July 06, 2006, 12:57 PM by jimwise68 »
Sanmarcopizza
Re: Profile crank tool
« Reply #1 on: July 06, 2006, 12:50 PM »
Maybe Edwardes in Camberwell ?
Offline jimwise68
Re: Profile crank tool - where can I buy and what are the benefits
« Reply #2 on: July 06, 2006, 01:00 PM »
Can the cranks be fitted without one?
Sanmarcopizza
« Reply #3 on: July 06, 2006, 01:16 PM »
Potentially yes. Just make sure the arms are lined up correctly, it's easy to get them a spline out so theay are not at 180degrees. You need to make sure you have approximated the spacing right so you don't need to take and arm off. If the arms are really snug you may need to tap them on with a rubber mallet or hammer/block of wood, until you can get the crank arm bolts engaged. You can then tighten the arms on with the bolts. If you are using the "Bitchin Bolts" (flush with hex hole) you need to be careful cos it's difficult to generate enough pressure with an alan key. The Prfile crank tool doesn't push the arms fully on, so you need to resort to the bolt method even with one.
Offline jimwise68
« Reply #4 on: July 06, 2006, 01:30 PM »
the bolts that I have are  normal bolts for the crank arms and not allen bolts, will that mean I wont need an tool?
Will I just be able to do them with a normal socket set?
Hope so, cos I want to fit them tonight.
Offline BrianP
« Reply #5 on: July 06, 2006, 01:40 PM »
should be okay jim, they'll be snug to get on, but i don't reckon too many sets out there are fitted using the profile tool.
as sanmarcopizza says, make sure the cranks are lined up correctly so ur not a spline out, but this is fairly easy to spot b4 u've the arm on fully anyway.
block of wood and a hammer's a good method of persuasion, then run them up snug using the actual spindle bolts.
good luck, and keep the swear box handy...
bp.
Offline jimwise68
« Reply #6 on: July 06, 2006, 02:34 PM »
Just got to get the bearings out of the US BB now. To convert them to mid size.
That is gonna be the b'stard.  :-[
Sanmarcopizza
« Reply #7 on: July 06, 2006, 02:57 PM »
I'm sure that shouldn't be too hard, just watch you don't damage the seals. You need to find a hard surface with a gap in it. Wide enough so that the outer face of the cups sits on it, but with a gap so that the bearing can drop through when you tap it. Some gentle heat on the cup may help. As the cups are allumium, but the bearings are steel they should heat up quicker and expand faster than the bearings.
Offline jimwise68
« Reply #8 on: July 06, 2006, 03:01 PM »
San is the man!  :4_17_5:
Offline BrianP
« Reply #9 on: July 06, 2006, 03:48 PM »
check out the length of the bearing spacer tubes with the us bb too jim.
u may need to shorten the (aluminium) tube, unless they've started supplying one suitable for mid bb's now?
and watch out for the bearing seals (only plastic) if ur doing any heating of the cups...
bp.
Offline jimwise68
« Reply #10 on: July 06, 2006, 03:52 PM »
Brian
'tis okay, the local friendly Condor bike shop has just removed the bearings for me!  :4_17_5: :4_17_5:
Just gotta do rest tonight.
Can't wait cos it means my  newey will be rideable.  :smitten:
Offline BrianP
« Reply #11 on: July 06, 2006, 05:27 PM »
post a pic or three, yeah?
bp.
Offline jimwise68
« Reply #12 on: July 06, 2006, 05:38 PM »
Gonna build it all up tonight.
May take step by step pix of the crank build.  :daumenhoch:
greentoad
« Reply #13 on: July 06, 2006, 09:58 PM »
Hi all
While we are talking Profile Cranks, I need to remove the arms and spindle etc from the Profile Champ Pro that I recently got.
What's the best way to get them off from a bike that has been left out side for 20 years?  :-[
The bolts and pedals have come undone very easily, but I now need to strip the rest and need help or a picture of what they are like, and the procedure for this. (They are in very good condition overall and may be okay with just a polish, so I really don't want to damage anything)
Any Help?
J.
Offline Rombloke
  • do one
« Reply #14 on: July 06, 2006, 10:21 PM »
Hi all
Any Help?
J.
by using the removal/fitting tool that jim is asking about....
Dave
haro, how do you do
Offline jimwise68
« Reply #15 on: July 07, 2006, 09:21 AM »
Dave
what about if you don't have one?
I was thinking the same thing last night, getting the crank arms on is a b'stard, god knows how I am gonna get the mo'fos off!  :LolLolLolLol:
Sanmarcopizza
« Reply #16 on: July 07, 2006, 09:25 AM »
Getting profiles off is brutal, unless they are worn a bit and slide off easy. I would recommend the use of the correct tool. Basically all it is a big nut with a shoulder that sits against the end of the spindle. You then make at it like a madman with a hammer and bash it until you have knocked the spindle through the arm. You could use an appropriate sized drift, byt there is a chance you will flatten the end of the spindle and not be able to get a bolt in again. I think there are some PDF manuals on the profile racing web site.
Offline BrianP
« Reply #17 on: July 07, 2006, 10:18 AM »
if you don't have the profile tool and are having diffs beating the spindle through to get the arms off, if you use a washer small enough to drop through the crank arm splined hole but big enough to cover as much of the end of the spindle as possible (to protect it and spread the loads) and set this onto the spindle, then tighten down an allen head bolt of the same thread as the regular hex head spindle bolts, this gives a good solid base to put a bit of solid bar against to drive the spindle thro.
(use an allen head bolt / machine screw cos it's smaller than a hex head and will definitely clear the crank arm splined hole on the way through)
BUT
u gotta make sure that the allen head bolt is proper tight (and stays tight!), so u don't feck the threads in the spindle.
one other thing, spread some grease on the spindle splines b4 assembly. really helps next time u dismantle....
bp.
Offline jimwise68
« Reply #18 on: July 07, 2006, 10:32 AM »
Right,
gonna buy me'sen a profile tool then.
I put loads of grease on the splines of the crank arm I have fitted. So hopefully, fingers crossed...
Offline Rombloke
  • do one
« Reply #19 on: July 07, 2006, 05:33 PM »
they are like 7 quid or sommat so just go buy one you tight minge
Dave
haro, how do you do
Offline jimwise68
« Reply #20 on: July 07, 2006, 11:29 PM »
I did, but it was more like £14 from Alans.
Offline Rombloke
  • do one
« Reply #21 on: July 08, 2006, 06:27 PM »
really...you was had
lol
Dave
haro, how do you do
« Reply #22 on: July 08, 2006, 06:28 PM »
yeah i have one you could borrow if needed lol
mine was free
Offline Rombloke
  • do one
« Reply #23 on: July 08, 2006, 06:38 PM »
http://www.customriders.co.uk/prodshow.asp?id=2175&pg=2&site=3
there you go 5 quid plus post.....good old custom riders
Dave
haro, how do you do
Offline jimwise68
« Reply #24 on: July 09, 2006, 10:14 PM »
Feckin northerners!   :LolLolLolLol:
Mind you at least a will get a free Alan's sticker!  :D
