976244 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 08, 2026, 10:52 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  What size headset ?
Author Topic: What size headset ?  (Read 4914 times)
Offline rick1970
What size headset ?
« on: September 27, 2012, 05:05 PM »
Hi folks ive got a 2008 repop aero pro burner build on the go and discovered it doesnt run a standard 1'' headset   :(   any ideas links most welcome  :daumenhoch:
Offline not johndub71
Re: What size headset ?
« Reply #1 on: September 27, 2012, 05:59 PM »
http://www.burnerworld.co.uk/2007AP_Flyer.htm
If this is it, standard 1 inch threaded.
Facebook/Fr35Hair
Offline rick1970
« Reply #2 on: September 27, 2012, 06:32 PM »
  yep one of them and tried a tange 1'' but theres no chance thats gunna fit a tad too big  :knuppel2:
« Reply #3 on: September 27, 2012, 08:17 PM »
I had an Anni TAP last year and discovered the same problem Rick, couldn't be arsed then, and flogged it. ::)
« Reply #4 on: September 27, 2012, 09:04 PM »
Rick , you need one with a outside diameter of 30.2mm  ;)  our headsets we usually use are around 32.8 ish
This should do the trick  http://www.ebay.co.uk/itm/1-THREADED-BIKE-HEADSET-HEAD-SET-/280653184835?pt=UK_sportsleisure_cycling_bikeparts_SR&var=&hash=item41583bbf43
As daft as it sounds ,,,, Don't order the BMX one  . You need one of the first two in the description with the 30mm measurement .
Better still ... I was at Johns ( JTSmooth) the other week and im 99% sure he has some very nice NOS Tioga ones  8)  Send him a PM
If your struggling or unsure send me a PM :daumenhoch:
Offline rick1970
« Reply #5 on: September 27, 2012, 09:53 PM »
thanks joff  :daumenhoch: gunna take a trip to bike shop tmoz see if i can get sorted fingers crossed  ;)
« Reply #6 on: September 28, 2012, 12:56 AM »
So that Tange one I finally remembered to post to you Rick isn't gonna fit either :-[
You'll have to build something else now >:D
Offline senzo milano
« Reply #7 on: September 28, 2012, 08:45 AM »
I do have 2 Epoch headsets witch are to small to fit a  standard  OS bmx ..  :(
i will take up the size this evening... but there is way to much space between the cup and the headtube...  ???
Big bobbles ,no troubles
« Reply #8 on: September 28, 2012, 10:46 AM »
Doesn't sound daft, it's a burner not a BMX
 >:D sorry only messing
Offline MaD-RoK
« Reply #9 on: September 28, 2012, 11:08 AM »
You need the road bike racer type 1 inch headsets for them from memory. Not sure what the difference is but I know for sure a Chris King will fit.  :daumenhoch:
25th Anniversary Custom Team Pro
Offline MaD-RoK
« Reply #10 on: September 28, 2012, 11:11 AM »
« Reply #11 on: September 28, 2012, 11:45 AM »
Sizing if it helps? http://chrisking.com/specs/headsets_all
Yeah , they would do ... doubr Rick will want to spend Chris king money on the burner though  :D
 Like i said he needs a cup size of 30.2 , the top nut remains the same at 1" ie standard old school BMX  :daumenhoch:
Speak to JTSmooth Rick ... he has what you need  ;)
Offline MaD-RoK
« Reply #12 on: September 28, 2012, 12:02 PM »
Prime tuned race machines matey!!!!  ;D
:4_17_5: :4_17_5: :4_17_5: :4_17_5:
« Reply #13 on: September 28, 2012, 12:49 PM »
Nothing against Burners myself ....... I have two  :D One being a 84 Team aero pro  8)
750Rush
« Reply #14 on: September 28, 2012, 03:39 PM »
If it helps, I've just bought a Peugeot CPX-50 16 frameset. I offered up the cups from an 80's raleigh burner and they were too big. I've just tried one of my three 25th anni headsets and the cups look like they will bash in no problem  ;)
Offline rick1970
« Reply #15 on: September 28, 2012, 07:10 PM »
Thanks for all the input guys much appreciated  :daumenhoch:  joff gunna pm jt now see if he's got what i need , cheers for that  :daumenhoch:
Offline JT Smooth
« Reply #16 on: September 28, 2012, 08:28 PM »
Yep, Ive got Tioga's 30.2 in stock  :daumenhoch:
« Reply #17 on: September 28, 2012, 08:30 PM »
My commision is going up JT  :D
I'll have a look for those shims too mate  ;)
Offline rick1970
« Reply #18 on: September 28, 2012, 08:45 PM »
  Big hug joffy tott (0) mmm   :LolLolLolLol:  thanks guys  :4_17_5:
