976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 26, 2026, 07:29 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  removing a stuck freewheel with a stick
Author Topic: removing a stuck freewheel with a stick  (Read 6423 times)
« on: July 11, 2006, 02:13 PM »
i have been beating on this worn out freewheel for hours. broken every tool i have had in the little pin holes
so i got my mate to stick weld it together
then some more thwacks but this time on the sprocket teeth, allowing me to use a girthier drift.
and it flew off
bit brutal but i need the hub
Re: removing a stuck freewheel with a stick
« Reply #1 on: July 11, 2006, 02:15 PM »
i see he's keeping britain tidy.
« Reply #2 on: July 11, 2006, 02:17 PM »
also if you put it in a vice, it crushes the outer race, and you can use the wheel for leverage.
never had one stay put with that method.
« Reply #3 on: July 11, 2006, 02:20 PM »
we tried that just before the sticker welder come out
« Reply #4 on: July 11, 2006, 02:22 PM »
surprised. they have always dropped off with that method. and ive had some old rusty shite thats been sat in the rain for 20 years.
« Reply #5 on: July 11, 2006, 02:38 PM »
i didnt really want to do the vice up too tight, in case it deformed the hub
« Reply #6 on: July 11, 2006, 02:47 PM »
ah...thats where you chickened out...ive wondered about it, but ive never crushed a hub either, or even worn the threads...the alloy seems to be a lot more flxible than the hardened steel of the freewheel.
motomagII
« Reply #7 on: July 11, 2006, 06:06 PM »
bike shop near me does that squashed  in vice turn and off they come every time
« Reply #8 on: July 11, 2006, 06:47 PM »
is that the rom bin :LolLolLolLol:
Offline Rombloke
  • do one
« Reply #9 on: July 11, 2006, 06:52 PM »
all the rubbish at rom goes into the rom rubbish magnet.....the performance bowl
Dave
haro, how do you do
« Reply #10 on: July 11, 2006, 07:57 PM »
next time i will vice it harder
with the stick welder, it took literally one touch
« Reply #11 on: July 11, 2006, 10:10 PM »
well, whatever works is correct. heat probably helped too.
« Reply #12 on: July 11, 2006, 10:15 PM »
now i have a fixed wheel freewheel
like craig strong had
« Reply #13 on: July 11, 2006, 10:16 PM »
i used a air chisel to get the one of from the deep blue sea wheels of funmonster
took about 2 secs lol after soaking and beating it for 2 days with a chisel
bof
« Reply #14 on: July 12, 2006, 06:58 PM »
if you dont want the freewheel take it to bits, remove all the bearings and the pawls. it will give you 2 nice flats that you can grip in a vice.Put a tyre on and use the wheel diameter as leverage, hay ho away you go. it is a mighty fine feeling when a freewheel is removed.
« Reply #15 on: July 12, 2006, 06:59 PM »
how do you strip the freewheel when it is on the hub?
Offline sawzall
« Reply #16 on: July 12, 2006, 08:27 PM »
the way i have done it is to weld a solid bar about 12" to free wheel so it does not move then use bar to lever off freewheel,also heat from welding helps free it, this saves beating the sh*t out of it risking damage to hub,just remember to cover up hub with wet rag, because weld spatter will burn alloy hub and fook it :daumenhoch:
« Reply #17 on: July 12, 2006, 09:50 PM »
I think its probably too late, but I have a hub that I stripped off a knackered rim and I want to get the freewheel off, any way of doing it before I rebuild the wheel?????? :idiot2:
« Reply #18 on: July 12, 2006, 09:52 PM »
they have a bearing cap with either two holes or more undew this and the bearings and stuff fall out
unless its the new db ones and thats on the inside lol
and ratty use a air chisel mate of in secs
« Reply #19 on: July 12, 2006, 09:58 PM »
Ta Mate, now to find me a mate with an air chisel???
« Reply #20 on: July 12, 2006, 10:45 PM »
i work in the motor trade so was in a bodyshop
working and asked the guy to have a go lol
« Reply #21 on: July 13, 2006, 09:00 AM »
you are gonna struggle
rebuild the wheel loosely
it will save trying to hold the hub still and wrecking it
Offline sawzall
« Reply #22 on: July 13, 2006, 07:12 PM »
you can very carefully use a disc cutter to remove it ,removing a bit at a time with patcience it will come off i saved a bullseye hub this way :daumenhoch:
« Reply #23 on: July 13, 2006, 09:44 PM »
fook all methods but the vice one
i turned off 2 long term stuckies with a vice today
the stickweld was good, but the vice is nice
