976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 26, 2026, 06:03 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  How do I remove sealed bearings from a bottom bracket?
Author Topic: How do I remove sealed bearings from a bottom bracket?  (Read 3686 times)
hooga1975
« on: July 13, 2006, 02:08 PM »
As above.  I do not want to smash them out because I want to use them again, but I want to change my cranks.
Lee
Re: How do I remove sealed bearings from a bottom bracket?
« Reply #1 on: July 13, 2006, 02:10 PM »
with a big screwdriver/punch. its easier than you think.
Preston Pirate
« Reply #2 on: July 13, 2006, 02:12 PM »
You can use a bearing puller, it fixes inside the inner race from the outside and would rest aagains the frame, you then use a screw thread to pull be bearing out of it's seat.
You'll be able to hire one from HSS or the like...
The other way is to hammer them out with a drift, but you run the risk of knackering the bearings with the harsh impact.
hooga1975
« Reply #3 on: July 13, 2006, 02:17 PM »
nice one.  The bearings are now out and in one piece!
Preston Pirate
« Reply #4 on: July 13, 2006, 02:35 PM »
selfpreservation
« Reply #5 on: July 13, 2006, 11:25 PM »
so how did you do it
hooga1975
« Reply #6 on: July 14, 2006, 03:12 PM »
I used the hammer and screw driver technique, and gave them a good old whack!
FuNMoNsTeR
« Reply #7 on: July 14, 2006, 06:04 PM »
For future reference:
 You can cut out some rubber discs from some thick rubber sheet and place these inside the bb shell covering/protecting the bearing race/cup to be removed before you whack it ;)
Next weeks top tip:
 How to remove those pesky boxer stains when you have followed thru trying to remove rusty pedals.
selfpreservation
« Reply #8 on: July 14, 2006, 08:02 PM »
sorry for being blonde but what precisley did you do as i may be changing frames soon(fingers crossed)
hooga1975
« Reply #9 on: July 14, 2006, 08:12 PM »
I slid the one piece cranks through as far as I could.  I the poked a long thin screw drive into the gap in the bottom bracket and gently tapped round the bearing until it popped out.  It was easier than I thought it would be.
