976243 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 08, 2026, 09:24 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  wobbly aero zytec
Author Topic: wobbly aero zytec  (Read 2083 times)
chubby
wobbly aero zytec
« on: November 14, 2012, 11:51 AM »
Got a slight wobble in an aero zytec  >:(
does the putting in a freezer work  ???
Or am i fooked
cheers all...
Offline MaD-RoK
Re: wobbly aero zytec
« Reply #1 on: November 14, 2012, 11:53 AM »
You mean its buckled? Or is the hub wobbly. The freezer will keep it until xmas, thats about it.
Offline Dannywhac
  • return of the whac
« Reply #2 on: November 14, 2012, 11:54 AM »
Have a search - there's a thread over at the museum (and here) about using a set of forks and some laggy bands over time to unbuckle.
There's also a thread over the museum about making a homemade press to sort it.
Either way it's a fair old amount of time to wait to unbuckle. And no, popping them in the freezer don't work :)
chubby
« Reply #3 on: November 14, 2012, 12:00 PM »
thanks fellas the hubs had a whack so best check that first.......
I'll keep the chips n chicken nuggets in the freezer  ;D
chubby
« Reply #4 on: November 14, 2012, 05:59 PM »
ain't the hubs  >:( >:(
anymore ideas anyone ??????
« Reply #5 on: November 14, 2012, 06:21 PM »
check the spindle isn't bent  ;)
Offline Dannywhac
« Reply #6 on: November 14, 2012, 06:36 PM »
If it's not the spindle, here's the link to the press idea:
http://bmxmuseum.com/forums/viewtopic.php?id=58417
Failing that you can mount them to a set of forks, and using laggy bands around the fork legs and around the buckle try and pull them back over time.
Never tried it meself.
Offline not johndub71
« Reply #7 on: November 14, 2012, 06:51 PM »
Wouldnt warming them up help them relax back into shape? OK, heat the wheel up while in a fork so you could see the buckle. Fancy hair dryer with a cold blast button would be best. Heat the wheel up from hub upwards to buckled section, give it a bit of pursuation into place while heating it up, then if straight, blast it cold to set it's position. Worth a try.
Facebook/Fr35Hair
chubby
« Reply #8 on: November 14, 2012, 07:49 PM »
never checked that  :uglystupid2: I've got a set i know are ok
Will pop it in n see thanks mate
« Reply #9 on: November 14, 2012, 08:50 PM »
If the hubs are not tightened up right, they can have a little wobble
but i have found that they were made a bit like that, and have a wobble in them from the start - some are good and some are... just bad with a wobble  :D
chubby
« Reply #10 on: November 14, 2012, 08:59 PM »
cheers B i know they were never spot on but this ones quite bad
not even a rider at the mo !! It's got a right wobble on ...
chubby
« Reply #11 on: November 14, 2012, 09:04 PM »
Thanks for the link fella looks a bit of a faff but sounds like it works though  :daumenhoch:
