976239 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 05, 2026, 02:22 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Crank removal tool for 3 piece cranks? (PIC ADDED) Please Look!
Author Topic: Crank removal tool for 3 piece cranks? (PIC ADDED) Please Look!  (Read 5979 times)
Can someone put up a link for a crank removal tool for redline and peregrine 3 piece cranks.
Been having a look on ebay but some don't say what cranks they remove!  :-\
Thanks in advance  :daumenhoch:
« Last Edit: December 18, 2012, 04:54 PM by BMX1973 »
bof
Re: Crank removal tool for 3 piece cranks?
« Reply #1 on: December 14, 2012, 06:48 PM »
You should not need a tool to remove these cranks, if you undo the pinch bolt , this should loosen the cranks grip on the spindle allowing them to be removed without a great deal of force, hope that makes sense
Offline Jon The Bassist
« Reply #2 on: December 14, 2012, 06:55 PM »
If you're having trouble just let me ride them for a bit - I can make any 3 piece crank disassemble :crazy2:
« Reply #3 on: December 14, 2012, 06:56 PM »
Here you go all the perfect crank removal tools  :LolLolLolLol:....
« Reply #4 on: December 14, 2012, 07:24 PM »
I've never removed a 3 piece before and not tried it on mine yet.
Once I removed the arms, I thought I needed one of these tools to remove shaft bit inside bottom bracket  :-\.
http://www.ebay.co.uk/itm/300774839971'ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Also how do you remove bearings, is it the same one as you remove one piece bearing cups.
« Last Edit: December 14, 2012, 07:28 PM by BMX1973 »
« Reply #5 on: December 14, 2012, 07:31 PM »
The crank extractor is only for cranks that use a square taper (or similar) axle and have no pinch bolt. Bit of wood and mallet hammer also used to tap out bearing cups and the bearings themselves from the cups.
Post a picture up if you're unsure :daumenhoch:
Mdbh
« Reply #6 on: December 14, 2012, 07:32 PM »
Screw driver+rubber mallet is the only tools you need;)
« Reply #7 on: December 14, 2012, 07:50 PM »
Thanks for advice chaps I'll have to get frame out and have a look.
Yes I dont think the cranks were the pinch type, so would the tool below work?
I'll post some pics if I get stuck.
« Reply #8 on: December 18, 2012, 04:53 PM »
Heres a pic chaps.
1) I've removed the nut and washer off the crank arm.
2) How do I remove the crank arms (as you can see its not the bolt type on arms, like a spline inside)?  :-\ Is it just a hammer, a block of wood against the arm and tap it off?  :-\
3) Then how do I remove the bottom bracket?  :-\
I know it may seem easy questions, but I've never dealt with 3 piece cranks before, as I only ever used 1 piece.  :-[
« Last Edit: December 18, 2012, 05:39 PM by BMX1973 »
HEYWOOD BMX
Re: Crank removal tool for 3 piece cranks? (PIC ADDED) Please Look!
« Reply #9 on: December 18, 2012, 04:57 PM »
Is there a thread inside the end of the arm for a puller tool? If not then one of these should work.
http://www.customriders.co.uk/prodshow.asp?prodid=7975&cat=0&parent=0&sid=3
Offline Betty
« Reply #10 on: December 18, 2012, 06:14 PM »
Socket set extension bar against the spindle and hammer :daumenhoch:
« Last Edit: December 18, 2012, 06:16 PM by Betty »
2 minutes turkish...
Offline rooski
  • Mons Veneris
« Reply #13 on: December 18, 2012, 06:26 PM »
Need more pics dude :)
Offline Dannywhac
  • return of the whac
« Reply #15 on: December 18, 2012, 06:33 PM »
Use the socket set extension like Betty said. Failing that fella, you can have a lend of my Profile removal tool if you like, although as it's near Chrimbo the post prolly won't get it to you before the 25th :)
Quick edit - I'm off to the posties tomorrow, so if you want to borrow one of my Profiles tools, pm me your addy and I'll send it tomorrow.
« Last Edit: December 18, 2012, 06:57 PM by dannywhac »
« Reply #16 on: December 18, 2012, 07:06 PM »
Thanks for the offer, seems a bit silly posting if I can get one cheap just need to know what one.
Happy to buy a second hand one off you, if you have 2. Send me a pm with PP details.
Don't really understand how the socket set extension works.
Offline Dannywhac
« Reply #17 on: December 18, 2012, 07:10 PM »
No worries - don't really want to flog one as it's good to have spares (having broken two wellying cranks out....no cranks were harmed though :) )
The socket extension - take the female (sticky-inny bit) end, making sure it's not larger than the crank spindle, pop that end onto the top of the crank spindle and hammer the poop out of the male (sticky-outy) end. Job done.
« Reply #18 on: December 18, 2012, 07:23 PM »
Thanks mate I think I know what you mean now.
Do you know of any place that stock them in UK?
« Reply #23 on: December 18, 2012, 08:17 PM »
You can make your own tool for pulling arms on or off. All you need is a longer bolt and a bunch of penny washers taped together.
To get your cranks apart right now, put the bolt back in the arm, but leave it a turn or two loose. give the head of the bolt a whack with a hammer - you'll see things start to move. Loosen the bolt a little more and give it another whack. Assuming it's all moving now, take the bolt out before you do any damage to the threads and as others have said, use the extension bar from a socket set (or any other decent drift) and continue knocking the axle through. Eventually a crank arm will fall off, you can then knock the axle and other arm out of the bike completely. Three piece cranks are supremely simple, the axle just sits within the bearing and can be tapped in and out easily. The whole thing is clamped in position and held tight by the crank arms.
Be sure to reassemble with a good amount of copper grease on all mating surfaces.
Offline Dannywhac
« Reply #24 on: December 18, 2012, 08:23 PM »
Just realised I've got these in me photobucket, might help for a spot of reference.
Profiles assembled how they'd be on a bike:
Disassembled:
