976333 Posts in 138997 Topics by 6434 Members - Latest Member: Darbs August 07, 2026, 03:59 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  MX1000/900 Potts Mod
Author Topic: MX1000/900 Potts Mod  (Read 1691 times)
Offline Gnarlyscoots
  • BANNED
« on: February 04, 2013, 02:56 AM »
Okay, before I go drilling the QR off my front 900, I have heard, and read through other threads on here, that it is possible to convert it for potts mod without removing the QR.
I can get a Weinmann adjuster for this purpose, the same as the DC one on a Nippon with the added pinch bolt but, how do I go about securing the cable in the QR? A Nippon QR has a large opening on one side for the cable outer which butts up inside to a smaller hole for the cable inner only to come through thus, securing the cable in the QR.
The MX1000/900 however, has the hole big enough for a pinch bolt.
How do I go about securing the cable? Any ideas?
Cheers  :daumenhoch:
BANNED
Offline benno
Re: MX1000/900 Potts Mod
« Reply #1 on: February 04, 2013, 09:30 PM »
can you not use the original weinmann adjuster on the QR ,
take the pinch bolt out and put it where the adjuster usually goes and bolt the adjuster
upside down through the QR where the pinch bolt was , if that makes sense  :)
i'm sure thats what i used to do bitd
It comes out of the ground!
Offline benno
« Reply #2 on: February 04, 2013, 10:03 PM »
A bit like this , might need to slightly file out hole to fit pinch bolt  :daumenhoch:
« Reply #3 on: February 05, 2013, 10:31 AM »
Mine & the Kapsters GJS Freestylers both use potts mod altered MX1000/900's  ;)
http://www.radbmx.co.uk/forum/index.php'topic=5816.0
Offline Glynnyboy
« Reply #4 on: February 05, 2013, 12:49 PM »
I'm sure I saw someone on here take the pinch bolt out of the quick release , then use a normal cable adjuster screwed in to the part of the release that held the pinch bolt.
Screwed in from the bottom obviously to house the cable outer, then the cable just threads through to meet the pots modded weinman adjuster your talking about.
I think there's a pic somewhere on here from the last time the question came up.
Found the pic.
If you do this you can leave the release on and use that weinman pots mod adjuster too.
« Last Edit: February 05, 2013, 06:55 PM by glynnyboy »
  • BANNED
« Reply #5 on: February 07, 2013, 11:57 AM »
Thanks guys. I have done just that. I took a normal adjuster, pushed it through and screwed the nut on from the other side to hold it tightly. I have a Weinmann adjuster on it's way to me that is the same as the DC adjuster with the pinch bolt incorporated that will sit in the top.
As soon as I have it, I will post some pictures of the setup  :daumenhoch:
BANNED
« Reply #6 on: February 07, 2013, 02:23 PM »
with the 1000 you might find the top part of the caliper hits the downtube if you spin the bars?  ???  they're quite high from what i remember
« Reply #7 on: February 09, 2013, 12:55 PM »
Found this pic in my Pbucket  ;)
