976241 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 06, 2026, 10:19 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Dp freestyler forks to small for bearing race.. Help
Author Topic: Dp freestyler forks to small for bearing race.. Help  (Read 1983 times)
Offline spadey99
« on: February 22, 2013, 12:59 PM »
Hi guys
As you know I bought a dp freestyler and thought I wound start the build today. Got a few headsets so went to out the bearing race on the forks and it was far to big!!!!  :(
Tried a few more from other headsets and all the same far to big and slop about.
Do I need a certain one or size? Just want to get on with my build.....
Steve  :-[
Bikes are there to be ridden, so why do I have so many.....
Sid1972
Re: Dp freestyler forks to small for bearing race.. Help
« Reply #1 on: February 22, 2013, 04:21 PM »
it happens mate, cut a coke tin down and pack it out around the bottom of the forks and drive the race on - best fix...
Offline Peter J
  • I have issues
« Reply #2 on: February 22, 2013, 04:29 PM »
Sid's 100% spot on as always  :daumenhoch:
« Reply #3 on: February 22, 2013, 04:57 PM »
What headset have you purchased. All my dips are as tight as. Try a beartrap 2 I went to a local bike shop and go a new 1" headset and had the same thing :daumenhoch:
dannyrobo2012
« Reply #4 on: February 22, 2013, 05:04 PM »
spartacus on here his head sets fit like a glove and only £35 delivered :)
« Reply #5 on: February 22, 2013, 05:12 PM »
Although bottom races often don't fit and need either filling or packing, is it defo bmx headsets you are trying?
 Normal bike 1" headsets are a different size to bmx 1" headsets
punkdSICO
« Reply #6 on: February 22, 2013, 08:13 PM »
I had the same issue with a DP Freestyler.  Coke can trick is the way to go:
Good luck,
Paul
Offline spadey99
« Reply #7 on: February 22, 2013, 08:14 PM »
thanks guys, yeah its a BMX one...... I found a tightish one but wiill contact spartacus as they look awesome, thanks guys
 :daumenhoch: :daumenhoch:
Sid1972
« Reply #8 on: February 22, 2013, 08:24 PM »
yep, when its still loose use a can.... :LolLolLolLol:
Offline spadey99
« Reply #9 on: February 22, 2013, 08:33 PM »
Heres a couple of pics guys of how shes looking at moment.....
Few things to change like stem , bars, seat, seatpost...... But looking sweet so far  :daumenhoch:
« Reply #10 on: February 22, 2013, 08:39 PM »
That looks well small, is it a 16"
Nice colour scheme though.  :daumenhoch:
Offline spadey99
« Reply #11 on: February 22, 2013, 08:58 PM »
ha ha no mate she is a full size 20" beauty........ :crazy2: :crazy2:
« Reply #12 on: February 22, 2013, 09:35 PM »
Welcome to the lower cheaper frames from back in the day Adam  ;D  this one looks very sweet  >:D and now worth big money - times has changed for the better  :daumenhoch:
