976239 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 06, 2026, 06:02 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Best way to remove pedal caps?
Author Topic: Best way to remove pedal caps?  (Read 1751 times)
Offline midschooljon
    • Make Your Bones
« on: March 10, 2013, 10:17 PM »
I've got a few sets of pedals that I want to do spindle swaps on. Problem is they have push in plastic end caps and I can't see how to remove them without causing damage. Anyone got any suggestions?
***Wanted - Cash waiting***
RAMP ROOM HOFFMAN FLASH
ELF Double Cross XL.
UGP plates and pad sets
Mid School Race Kit
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
Re: Best way to remove pedal caps?
« Reply #1 on: March 10, 2013, 10:22 PM »
Magic
Offline GavinDavis
« Reply #2 on: March 10, 2013, 10:29 PM »
Magic
Youve spent too much time talking to devilock  :LolLolLolLol:
Offline not johndub71
« Reply #3 on: March 10, 2013, 10:46 PM »
Usually, theres a small cut out, but either way, your cap is gonna get trashed. New caps time if ya want it new. You could drill a centre hole, and make a pin in the shape of a L. Pop it in and pul out. Other option is  A T T A C K.
Facebook/Fr35Hair
Offline Betty
« Reply #4 on: March 10, 2013, 10:48 PM »
I just use a couple of small screwdrivers and gently does it  :daumenhoch:
2 minutes turkish...
« Reply #5 on: March 10, 2013, 10:54 PM »
what mark said^^^^^
i bought a set of them micro screw drivers out the pound shop and they work spot on.
Offline bobbbbsy
« Reply #6 on: March 10, 2013, 10:59 PM »
stanley it far back and lever it out. you ll never see the mark once refitted if you do it right . practice on some shitters  :LolLolLolLol:
« Last Edit: March 10, 2013, 11:02 PM by bobbbbsy »
« Reply #7 on: March 10, 2013, 11:29 PM »
I would have thought a good soak in hot water to soften them them a couple of stout wooden toothpicks/skewers would do the trick  :daumenhoch:
« Reply #8 on: March 10, 2013, 11:36 PM »
might be worth a try ? but you know the rubber helps unscrew jam jar lids, with the grip and twisting action - quite a few caps unscrew - might be worth a shot ?  ???
    • Make Your Bones
« Reply #9 on: March 11, 2013, 07:55 AM »
Cheers guys. I'll have a go at it and see which way works best.  :daumenhoch:
Mid School Race Kit
Offline stevesredvxr
« Reply #10 on: March 11, 2013, 09:56 AM »
Have a word with sbd as he's done a few pedals for me recently and the end caps are with the spindles and bearings in a little bag and aren't damaged at all.
Not even a mark.
 :4_17_5:
