976239
ludwig242
May 06, 2026, 06:04 PM
Best way to remove pedal caps?
Topic: Best way to remove pedal caps? (Read 1752 times)
midschooljon
Flip-Whip
March 10, 2013, 10:17 PM »
I've got a few sets of pedals that I want to do spindle swaps on. Problem is they have push in plastic end caps and I can't see how to remove them without causing damage. Anyone got any suggestions?
***Wanted - Cash waiting***
RAMP ROOM HOFFMAN FLASH
ELF Double Cross XL.
UGP plates and pad sets
Mid School Race Kit
Jaan
Tail Whip
A.K.A. Chris
Re: Best way to remove pedal caps?
March 10, 2013, 10:22 PM »
Magic
GavinDavis
BMX Nerd
March 10, 2013, 10:29 PM »
Quote from: Jaan on March 10, 2013, 10:22 PM
Magic
Youve spent too much time talking to devilock
not johndub71
Look Back
March 10, 2013, 10:46 PM »
Usually, theres a small cut out, but either way, your cap is gonna get trashed. New caps time if ya want it new. You could drill a centre hole, and make a pin in the shape of a L. Pop it in and pul out. Other option is A T T A C K.
Facebook/Fr35Hair
Betty
900 Air
March 10, 2013, 10:48 PM »
I just use a couple of small screwdrivers and gently does it
2 minutes turkish...
dordymush
Berm Worm
March 10, 2013, 10:54 PM »
what mark said^^^^^
i bought a set of them micro screw drivers out the pound shop and they work spot on.
bobbbbsy
900 Air
March 10, 2013, 10:59 PM »
stanley it far back and lever it out. you ll never see the mark once refitted if you do it right . practice on some shitters
Last Edit: March 10, 2013, 11:02 PM by bobbbbsy
oldschoolace
Team Moderator
Double Flip Whip
Bodger
March 10, 2013, 11:29 PM »
I would have thought a good soak in hot water to soften them them a couple of stout wooden toothpicks/skewers would do the trick
BENDYCAT ELEVENTEEN
Berm Worm
"Click here for link"
March 10, 2013, 11:36 PM »
might be worth a try ? but you know the rubber helps unscrew jam jar lids, with the grip and twisting action - quite a few caps unscrew - might be worth a shot ?
midschooljon
Flip-Whip
March 11, 2013, 07:55 AM »
Cheers guys. I'll have a go at it and see which way works best.
Mid School Race Kit
stevesredvxr
900 Air
March 11, 2013, 09:56 AM »
Have a word with sbd as he's done a few pedals for me recently and the end caps are with the spindles and bearings in a little bag and aren't damaged at all.
Not even a mark.
