976239 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 06, 2026, 05:15 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Cable Routing
Author Topic: Cable Routing  (Read 1864 times)
Offline GavinDavis
Cable Routing
« on: March 13, 2013, 12:13 PM »
Right then guys, im building my 2-Hip Stout Boy very soon and have stumbled across a bit of a problemo....
The rear brake will be an AD990 that is lugged on the chainstays, the gyro cables are routed on the downtube and then go through the bottom of the seat tube to where the brake is.....
The problem ive got is that there is literally just a hole that is drilled through the seat tube.  Its not threaded for a barrel adjuster or anything?
What can I use to mount inside the hole so that the cable can be adjusted nearer the brake?  Jaymz has recently encountered a similar problem with his and loosely pushed a barrel adjuster in place through the hole so that when the cable is under tension it doesnt move.  Is this the only way as my mind has gone blank  :-\
Re: Cable Routing
« Reply #1 on: March 13, 2013, 02:09 PM »
won't a barrell adjuster just sit in the hole and stay there with the tension on the cable?  does it need to be threaded?  ???
Offline Discostu
  • Two's Company
Re: Cable Routing
« Reply #2 on: March 13, 2013, 02:32 PM »
Yes as above. Just leave a barrel adjuster in the hole.  :daumenhoch:
Offline GavinDavis
Re: Cable Routing
« Reply #3 on: March 13, 2013, 02:32 PM »
Yep it will sit there under tension if i want it to.....Im just a bit more finicky  :LolLolLolLol:
Ideally i'd like it to sit in the hole nice and secure  :daumenhoch:
dp and Chopper Dude
Re: Cable Routing
« Reply #4 on: March 13, 2013, 02:39 PM »
Araldite the bugger in  :daumenhoch:
Offline GavinDavis
Re: Cable Routing
« Reply #5 on: March 13, 2013, 02:51 PM »
Offline not johndub71
Re: Cable Routing
« Reply #6 on: March 13, 2013, 07:24 PM »
How big is the seat tube hole?Could you not use an adjuster from a side pull caliper?
Facebook/Fr35Hair
leehunt1
Re: Cable Routing
« Reply #7 on: March 13, 2013, 09:20 PM »
Stop being so F@@KIN Anal gav and just stick it in..! :LolLolLolLol:
Re: Cable Routing
« Reply #8 on: March 13, 2013, 09:31 PM »
this is what I did with mine
Offline GavinDavis
Re: Cable Routing
« Reply #9 on: March 13, 2013, 09:36 PM »
Sounds good to me when you put it that way  :LolLolLolLol:
