976239 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 06, 2026, 04:27 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  stuck seatpost....
Author Topic: stuck seatpost....  (Read 1387 times)
cdt808
stuck seatpost....
« on: March 13, 2013, 10:35 PM »
So .... I have an old frame from which I hoped to remove a fluted seat post to use on another bike, but its stuck fast  :(
Have given it a good old heave ho whilst the saddle was on and, in frustration once the saddle was off,  a good tw*t with a lump hammer - which moved it further in by about 3mm.....
how the chuff do i get it out guys????   :-[
Offline Betty
Re: stuck seatpost....
« Reply #1 on: March 13, 2013, 10:40 PM »
Put the seat post in a vice and use the frame to twist it out, if you don't have a vice try clamping a stem to the post to give you a bit of leverage  :daumenhoch:
2 minutes turkish...
scary_leary
« Reply #2 on: March 13, 2013, 10:44 PM »
Drill a hole (near top) through the post, push metal bar/screwdriver through.. Twist n turn til out.
Offline jT Racing
  • i like bikes. :/
« Reply #3 on: March 13, 2013, 10:50 PM »
If all else fails you can saw it off and use a strong caustic mix to melt it out.
ding dong
Offline senzo milano
« Reply #4 on: March 13, 2013, 10:56 PM »
Maybe you can heat the tube a little ....
Big bobbles ,no troubles
« Reply #5 on: March 13, 2013, 11:00 PM »
If it's an aluminium frame drill it out as all the twisting and tuggind will probably snap the frame  :crazy2:
Offline bobbbbsy
« Reply #6 on: March 13, 2013, 11:14 PM »
as above. in the worst possible case a few devilocks may help !
or you can try bendys advice and leave it in coca cola overnight !  ::) :LolLolLolLol:
« Last Edit: March 13, 2013, 11:16 PM by bobbbbsy »
« Reply #7 on: March 14, 2013, 09:41 AM »
My stuck post wasa alloy renthal and it has fused to the metal frame - snapped the top trying to drill a hole in it to twist the top (it was fused)
if it has moved 3 mm then i would put it in a vice and twist it out using some man power  :knuppel2:
got it out in the end - just got to get it welded up from the previous owner
