976300
crissy_criss
June 26, 2026, 03:56 PM
Pro Class rim tape
Topic: Pro Class rim tape (Read 3037 times)
Preston Pirate
Pro Class rim tape
July 27, 2006, 09:47 AM »
A long shot I know but does anyone know where I can get hold of some Pro Class rim tape, I'm looking for the black/silver stylee stuff, cheers.
MartyC
Berm Worm
Re: Pro Class rim tape
July 27, 2006, 09:55 AM »
Other members have used Xmas Wrapping tape of the non sticky variety, apparently it works a treat as I am sure others will testify
Sanmarcopizza
July 27, 2006, 10:25 AM »
Apparently mylar (sp?) is the stuff you want, and sign writers use it.
Last Edit: July 27, 2006, 10:48 AM by Sanmarcopizza
Preston Pirate
July 27, 2006, 10:45 AM »
Cheers folks, when i find something suitable I'll post up
kdw712
900 Air
July 27, 2006, 12:28 PM »
you can often find pukka mongoose tape on the bay
but any shiny metallic ribbon should do
cheers Kev
{ wanted : "Red Haro Handle" brake lever
link to my trade post
stidds
Site Supporter
My life is Radbmx
Posts: I am a geek!!
July 27, 2006, 01:14 PM »
I went to a local craft shop and bought ribbon, they have loads of different sizes, styles and colours. Just put some rim tape over that to protect the inner tube.
sawzall
540 Air
July 27, 2006, 05:46 PM »
i used xmas ribbon on my ripper worked a treat,just make sure you pull it nice and tight,then stick with a strong tape carefully cut out valve hole with craft knife and fit new rubber rim strip,this holds it in correct position
AtariAger
Curb Endo
July 27, 2006, 10:06 PM »
This is just what you are looking for...
Click here for ALL colors
The best thing to do is to get a hold of some old nasty rim strips that nobody wants and just lay this ribbon right on top! Works like a charm!
Cheers...
Last Edit: July 27, 2006, 10:08 PM by AtariAger
Pro Class rim tape
