976239 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 06, 2026, 12:52 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Springfield brake problem
Author Topic: Springfield brake problem  (Read 1784 times)
« on: April 04, 2013, 07:33 PM »
just chucked a Springfield onto my rider...
soon as I tighten up the bolts on the brake mounts it stops working... my brake mounts are well short of the top of the brake ... so I can't tighten them up?
any ideas  :)
Offline Gary72
Re: Springfield brake problem
« Reply #1 on: April 04, 2013, 07:40 PM »
Talk to the LLP :daumenhoch:
Offline jT Racing
  • i like bikes. :/
« Reply #2 on: April 04, 2013, 07:40 PM »
D'oh
ding dong
« Reply #3 on: April 04, 2013, 08:38 PM »
Model shop and a bit of the right gauge brass tubing as a spacer collar is the easiest fix Ed  :daumenhoch:
« Reply #4 on: April 04, 2013, 08:40 PM »
What frame is it Ed?
Offline Munnyella
« Reply #5 on: April 04, 2013, 08:43 PM »
Don't tighten them right up, you don't need to.
the w4nky spring does the goods on these, so no need to nip `em up.
Lenny has a big bag of elastic bands for next week when the spring snaps!!!
MM
Offline GavinDavis
« Reply #6 on: April 04, 2013, 08:51 PM »
Not used the springfield myself Ed but cant you just loosen the bolt....tension the spring like a mofo and lock the bolt back down?
« Reply #7 on: April 04, 2013, 08:54 PM »
You haven't got it on upside down have you ed ? See one the other week
« Reply #8 on: April 04, 2013, 09:01 PM »
It's on my supercross Rob ... You just can't tighten it AT ALL.
Bit of tubing or some new mounts sounds like the way.
« Reply #9 on: April 04, 2013, 09:08 PM »
Stick a 990 hombre on it mate  :daumenhoch:
« Reply #10 on: April 04, 2013, 09:41 PM »
that could be it Pierre ... I put it on facing down like a 990 ... will try it the other way up  :daumenhoch:
« Reply #11 on: April 04, 2013, 11:52 PM »
hold on ... both arms are the same  ??? how can you get it upsidedown?????
LENNY-LENTINI
« Reply #12 on: April 07, 2013, 10:09 AM »
Haha
I put mine on upside down at first and flipped a right rage until I realised the bolts weren't long enough because it was on wrong.
Just flip it over Ed.
Oh and get to Asda for some laggy's.
Faith. L
« Reply #13 on: April 07, 2013, 09:53 PM »
Finally got to sit down and look at my brake ... Master Pierre was of course spot on - I guess thats the benefit of being one of the chosen ones with the halos ... you are always right  :daumenhoch:
... which was confirmed by the LLP representative  8)
Turned it over and all is well.
So I call BS on the review I read which said they were cheap as the calipers were from the same cast ... no way if both sides are recessed for the bolts when mounted  :crazy2:
Had no probs with mine when I went for a spin today .. even when they were upsidedown  ^"^
« Last Edit: April 07, 2013, 10:25 PM by ED209 »
Offline not johndub71
« Reply #14 on: April 07, 2013, 10:24 PM »
I had this with an oddy evo2. Mine was the brass inners of the u brake were too long. The bolts and washers are supposed to tighten to the lug on the frame. Mine just crushed the brass inner.
Facebook/Fr35Hair
