976346 Posts in 138998 Topics by 6449 Members - Latest Member: boba fett September 13, 2026, 07:47 PM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  What PSI should I be running in the tyres of this new school bike of mine ???
Author Topic: What PSI should I be running in the tyres of this new school bike of mine ???  (Read 4396 times)
Offline Funkyworm
Ok this new school fangled Subrosa thingy has tyres on it that say they go to 100psi
i'M 5'11 & (currently) a-hem just under 14 stone , So what should i run them at ??? & would it depend on where i'm riding ie hi-pressure for smooth park etc & softer on the road of does it simply come down to weight vs comfort vs not under or over inflating???
 Also One of the tyres has a flat, if thee tyre goes to 100psi is there a special inner i should be using?
Cheers :daumenhoch:
High as you dare Callum - bring it to the BR and you can run it about 80PSI first and then up it to 90 and see if it's any faster. Take it to 100 finally and see if it's still comfortable  ???
I run mine at 65 as they're only rated to this, but they are well faster with the higher PSI in :daumenhoch:
paulb113
I have also got a new school bike and have 55psi in both but feels too soft, I am 5ft 8,13 stone so may take mine up to 65psi . I have 100psi frequency G tyres in my old school bike at about 80psi and so much faster but shakes the old bones a bit :LolLolLolLol:
Offline Funkyworm
I pumped them up to around 80 today 7 after about an hour the front inner gave out around the valve,
Cant get the wheel of as it's got pegs on & i don't have a wrench that will reach through the peg Will look at it tomorrow. but thats why i was asking about inner tubes ??? The tyres should be fine they are Oddy Mike Aitkin front ones bigger than the back i'm assuming this is a usual set up ?
Offline bobbbbsy
max for your size and weight
Offline Betty
Bout 70-80 psi for me, 110 psi rated tyres
Owt higher i get sore wrists  ;D
Just go with what feels right for you  :daumenhoch:
2 minutes turkish...
Offline Wadz
  • Ride Ride Ride!!
65-70psi for me on the 100psi khe's
120  iin my KHE's
You're actually meant to have at least 120psi  in KHE Mac2's for warrantys sake
They don't blow till 220psi
as shown here  :LolLolLolLol:
Offline Betty
120  iin my KHE's
 ;D
'They canne take the pressure Captain"
5' 11" my arse  ;D
Offline Funkyworm
5' 11" my arse  ;D
OK Not measured my height since I've hit my 40's,,, might have shrunk a little :-[ ::) ::) ::) ::) ::) but only a little :LolLolLolLol:
Mdbh
100 all day long, bikes are too slow other wise! But then again I'm 15 stone :LolLolLolLol:
15 stone.....yeah right  ;D
Mdbh
Ok I'm not 15 stone I'm 14.11 so piss of :LolLolLolLol:
