976232 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 25, 2026, 03:50 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  NOS Frame Sets Question
Author Topic: NOS Frame Sets Question  (Read 6151 times)
« on: September 06, 2013, 08:17 AM »
I'm lucky enough to have a couple of NOS frame sets and forks, however some don't have a headset in.
I have always deemed that if you put a bottom bracket in, then it's game over, but where do us 'collectors' / 'show & shiners' stand with sticking a headset in, does that then lower values or change the appeal of an untouched item.
I remember some frame and forks, Curtis for example came with a beartrap headset fitted.
Yes yes, I know their there for riding, but what's your thoughts folks.......
Offline neil
Re: NOS Frame Sets Question
« Reply #1 on: September 06, 2013, 08:22 AM »
I'm of the opinion that as soon as any part is fitted its game over
« Reply #2 on: September 06, 2013, 08:35 AM »
NOS to me is in totally new in the wrapper .box.bag . If applicable .as soon as the item is un packaged . then it can only be called new unused old stock . However something with shelfware fading is often NOS but in poorer condition than something nuos.
« Reply #3 on: September 06, 2013, 08:54 AM »
I would say Nick, that if the frameset comes to you from the manufacturer with a headset fitted at the factory, then it can be called NOS.
If YOU fit a headset to a previously NOS frameset then it becomes New Unused Old Stock (NUOS  ;) )
« Reply #4 on: September 06, 2013, 08:58 AM »
Agreed Sean  :daumenhoch:   is it NUOS?  or NBF?  (used)  ;)
« Reply #5 on: September 06, 2013, 09:06 AM »
I hear you folks.......
I think what I'm saying is, should I want to display the items, either at MK or in my loft lol, do I fit a headset so the bloody things don't fall over - or leave as is !
« Reply #6 on: September 06, 2013, 09:08 AM »
with you Nick they'll fall over anyway  ;D
but personally for display i like to have a nice headset installed, just sets the frame set off  :daumenhoch:
« Reply #7 on: September 06, 2013, 09:10 AM »
This is my thought 2 b honest . I have had 2 do it  ::) but if u want 2 display it or build it hey ho. I have one the same and can't make my mind up either  :tumbleweed:
Offline Peter J
  • I have issues
« Reply #8 on: September 06, 2013, 09:10 AM »
My 2 pence worth
At the end of the day they are 30+ year old frames and really only good for a wobble around on certainly not up to modern riding
If its NOS then leave it as NOS, as a NOS frame/Part has as much aesthetic appeal as a complete build  :daumenhoch:
I admire anyone who has the patience and dedication to build a bike, however there are loads of "UN-NOS" parts and frames out there to use  :daumenhoch:
I have a few NOS parts that will never get built (not that I do build) I much prefer to see parts than complete builds as it reminds me of when I'd go on a Saturday to J.E James (LBS) and look at all the cool parts in the glass display case and occasionally afford to buy  :smitten:
I collect old fishing tackle as well and I'd never dream of using any of that  :idiot2: same applies for old BMX  ;)
Offline That Swan Guy
« Reply #9 on: September 06, 2013, 09:15 AM »
I fit a headset to stop the forks rattling around in the headtube and reduce the likely hood of damage.
« Reply #10 on: September 06, 2013, 09:19 AM »
Yep, that's my thoughts, but as Peter says, does that take away the aesthetic principle
Offline Peter J
  • I have issues
« Reply #11 on: September 06, 2013, 09:24 AM »
Cheaper than headsets and don't leave any marks  ;)
http://www.cw-racing.com/collections/accessories/products/frame-savers
Offline kalex
« Reply #12 on: September 06, 2013, 09:26 AM »
As above once fitted except from factory it's not NOS
But if you display the frame set can't you get some thin pipe insulation around the fork steer tube then wedge into the frame. This way nothing will get scratched or damaged, it will be a tight secure fit but also look as if built.
Offline Peter J
  • I have issues
« Reply #13 on: September 06, 2013, 09:27 AM »
Good Idea Kalex  :4_17_5:
and cheaper that the CW option  :daumenhoch:
and I'm all for saving money  :smitten:
Offline neil
« Reply #14 on: September 06, 2013, 09:28 AM »
Nick you could use pipe lagging in the head tube it'd keep the f£f stable and you wouldn't lose any of the nosness  :daumenhoch:
« Reply #15 on: September 06, 2013, 09:28 AM »
I promise you after postage it will be cheaper to buy a headset from Biagio.
Juan doesn't do postage cheaply.
Offline Peter J
  • I have issues
« Reply #16 on: September 06, 2013, 09:30 AM »
True  ;)
Looks like pipe foam option is the winner  :daumenhoch:
Offline neil
« Reply #17 on: September 06, 2013, 09:31 AM »
I didn't see Kalexs post :daumenhoch:
« Reply #18 on: September 06, 2013, 09:37 AM »
I've only ever owned 2 NOS frame and fork sets and I've built them both :-[
But I love them :LolLolLolLol:
« Reply #19 on: September 06, 2013, 09:45 AM »
Just had a think on this and here's my solution Nickers  :nuts:
Buy a tange road bike headset that looks old school but has smaller diameter cups that drop in the headset . Cut a thin piece of card the height of the head tube . Put inside headtube and push the cups inside the card . Crown race just use a dremel to grind away the inside so it drops on the forks with no force fitting. Then screw it all together . Nothing is force fitted so it all remains NOS  :daumenhoch:
What u recon  :surprise:
Offline kalex
« Reply #20 on: September 06, 2013, 09:51 AM »
Not only pipe insulation.  But bubble wrap could be wrapped around then duct tape around that to get just the correct size.
As long as its soft material anything can be used the tape around. Quick and easy thats the way to go
« Reply #21 on: September 06, 2013, 10:12 AM »
just sling em back in the loft Nick and forget about em  ;D
« Reply #22 on: September 06, 2013, 10:28 AM »
Genius Steve, top of the class, that man. :4_17_5:
Offline 58 delray
« Reply #23 on: September 06, 2013, 10:47 AM »
only issue i can see with this is that you will still have to screw the top race and lock nut on the forks thus possibly marking them and making them non nos.......
« Reply #24 on: September 06, 2013, 10:54 AM »
Who asked you.......thought you were banned?   ;D
