976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 03, 2026, 03:46 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  How to get that brushed aluminium finish on rims?
Author Topic: How to get that brushed aluminium finish on rims?  (Read 2653 times)
« on: September 09, 2013, 04:15 PM »
I am after doing something a little different on a pair of Araya Aero rims and am thinking that instead of doing the usual bling thing and that I would go for a brushed finish.
So, what would be the best way to get that brushed look on the rims and to get it even looking?
Re: How to get that brushed aluminium finish on rims?
« Reply #1 on: September 09, 2013, 04:19 PM »
Cupped piece of wet or dry in one hand, drop the rim in the paper and rotate the rim with your other hand  :)
« Reply #2 on: September 09, 2013, 04:21 PM »
Depending on the "grade" of brushed effect you want you could also use a good quality wire wool  :daumenhoch:
Offline bmxbandit
« Reply #3 on: September 09, 2013, 04:27 PM »
WIRE WOOL !!  "wantit"
use wet and dry 1200 or 1000 grade
use water and fairy liquid as well
cup the paper in your hand and grip the wheel then rotate round the rim
hope makes sense  :daumenhoch:
Offline jimwise68
« Reply #4 on: September 09, 2013, 04:37 PM »
Marty, put wheels on bike and then ride really fast through a long, dense bramble bush.  :daumenhoch:
« Reply #5 on: September 09, 2013, 05:11 PM »
 ;D
« Reply #6 on: September 10, 2013, 12:58 AM »
I did think about that but the thorns in the bramble bushes here are like the prawns; fooking huge!
Offline steve69
  • aka. Steve Changa
« Reply #7 on: September 10, 2013, 07:14 AM »
My thoughts on the above proposed methods are...
I don't think you will get an even finish between/around the raised spoke holes using the 'paper in a cupped hand' method  :-\
I would think a fine Scotch-brite pad used in the same way would be more successful.
Offline fischflo
« Reply #8 on: September 10, 2013, 08:50 AM »
/>this guy uses acetone before the sponge scrub sction -?-, then sands it a little ............gives that stripey look  :-\
Probably the acetone is simply to remove any finish. Brushed sounds good for rims, but just in case:
....perhaps you can get a more dull 'blasted' look by breaking up the long strokes into a trembling motion.
And/or by skipping the sand paper step ....   (hard to see the preliminary restult in the vid though)
or sand/bead/soda blast it  :D
Offline fischflo
« Reply #9 on: September 10, 2013, 09:04 AM »
- DIY Soda Blaster  :LolLolLolLol:
Offline 58 delray
« Reply #10 on: September 10, 2013, 09:57 AM »
send me some of those prawns then mate  :daumenhoch:  :LolLolLolLol:
Offline Rabdul06
« Reply #11 on: September 10, 2013, 09:57 PM »
Ive done this on a set of PC rims using wire wool. Also used wire wool on seat clamps and brakes etc before spraying them up with that anno looking paint....good stuff.
Offline BADDH
  • BMX
« Reply #12 on: September 20, 2013, 11:39 PM »
He's right your know, I have done this many times, works a treat.  :daumenhoch:
« Reply #13 on: September 21, 2013, 02:37 PM »
Scotchbrite pads have been purchased, hoping to make a start this week and will do some before and after pics.  A little test makes me think wire wool around the spoke holes then the scotchbrite  :daumenhoch:
