976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 03, 2026, 04:49 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  How to strip black MX 1000's ( update now with pics )
Author Topic: How to strip black MX 1000's ( update now with pics )  (Read 4102 times)
Offline benno
« on: September 10, 2013, 10:35 PM »
I've had em sat in nitromors for a few days and its not touched it !
Are they anodised black ? Is it an oven pride job ?
« Last Edit: September 17, 2013, 07:01 PM by benno »
It comes out of the ground!
Re: How to strip black MX 1000's
« Reply #1 on: September 10, 2013, 10:37 PM »
yep anno ya wally
fook me don't leave them in it too long tho kid
Offline CustardLips
« Reply #2 on: September 10, 2013, 10:41 PM »
yep anno ya wally
x2 or nail varnish remover and a cotton wool pad (takes a bit longer tho and a bit more elbow grease needed).  :daumenhoch:
"WWG1WGA"
Offline benno
« Reply #3 on: September 10, 2013, 10:47 PM »
Cheers  :buck2:
  • Andy
« Reply #4 on: September 11, 2013, 12:00 AM »
About 5 mins in oven pride should do the trick, but keep checking regularly. Don't leave them in for any longer than necessary. I usually remove after a minute or so, run the parts under a tap & wipe off to remove the gloopy stuff, then re-submerge and repeat. 5 mins should be more than enough. Polish up with autosol, and behold - a mint looking caliper  "wantit"
« Reply #5 on: September 12, 2013, 09:47 AM »
use a old tooth brush to get into the hard to reach places or it will leave black bits in places - the tooth brush can melt if left in
used peek for a mirror/chrome look
autosol little too harsh in my eyes for a clean look
Offline benno
« Reply #6 on: September 12, 2013, 05:51 PM »
Cheers lads  :daumenhoch:
Spen my calipers aren't that good so I'm gonna strip em and experiment
With some Canodising on em, thanks anyway :)
Offline Rabdul06
« Reply #7 on: September 16, 2013, 01:32 PM »
   I usually throw the part in a zip lock bag, add the oven cleaner, close the bag and rub it through the bag. Keeps everything in one place. Then when your done, wash the part with soap/water seal the bag up and lob it in the bin...
Offline MaD-RoK
« Reply #8 on: September 16, 2013, 01:39 PM »
Use Marigolds and paint it on with a small decorating paintbrush and keep moving the stuff around. Best way to not overcook them, do it in the sink and once the anno is off just switch on the tap. ;)
« Reply #9 on: September 16, 2013, 01:45 PM »
caustic soda will strip em in no time.
just keep an eye on em or you'll end up with half a caliper  :slayer:
« Reply #10 on: September 16, 2013, 07:37 PM »
Put a photo up of the results  :daumenhoch:
Offline benno
« Reply #11 on: September 16, 2013, 10:22 PM »
Got some oven pride and I'm gonna have a bash at em tomorrow night :)
Offline MaD-RoK
« Reply #12 on: September 17, 2013, 03:26 PM »
Or try this:
I use it to strip my missus. Prize every time....  :4_17_5:
Offline benno
Re: How to strip black MX 1000's ( update now with pics )
« Reply #13 on: September 17, 2013, 07:09 PM »
Job done
I used the oven pride in a plastic sandwich bag method ,
Basically I poured some oven pride in bag shoved the arms in for a few minutes rubbing them through the bag , then I fished em out and put them straight into a bucket of soapy water ,
Any black bits I missed I used a toothbrush dipped in the OP to clean the last few bits off ,
All the bits in the pics below were black and this is how they came out , I haven't even polished em
« Reply #14 on: September 17, 2013, 07:28 PM »
job done  :4_17_5:
Offline wilsey72
  • Thats corn that is.
« Reply #15 on: September 17, 2013, 07:30 PM »
Now that's magic...!
Result Benno, my turn next (my brake set not literally me).
 "wantit"
GLOUCESTER RIDE 28th July 2018
Offline garran
« Reply #16 on: September 17, 2013, 07:32 PM »
tip top
Offline wilsey72
« Reply #17 on: September 17, 2013, 07:42 PM »
Does anyone know how to split the levers successfully? :-[
« Reply #18 on: September 17, 2013, 08:01 PM »
It that a powdered type of oven pride you mix with water?
Great results  :4_17_5:
Offline benno
« Reply #19 on: September 17, 2013, 09:32 PM »
Nope it's liquid OP :)
Offline Sc0tty
« Reply #20 on: September 19, 2013, 07:07 PM »
Amazing results there, I need to buy some of that sh1t asap !!!! :)
« Reply #21 on: September 22, 2013, 09:27 PM »
