976229 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 23, 2026, 03:03 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  Identify the part...
Author Topic: Identify the part...  (Read 4340 times)
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« on: November 11, 2013, 12:20 PM »
Ok, this a little bit of fun and also a call for some RAD  "help"
As I've mentioned in another thread i'm planning on building a JMC DY replica.
I'm after help in identifying the parts from the pictures posted below?
I know most of it is pretty clear but there are 1 or 2 challenges in there… Any additional insider info like he typically ran 180s or a particular spoke pattern (4X ?) will be greatly appreciated…
Chris
Offline rooski
  • Mons Veneris
Re: Identify the part...
« Reply #1 on: November 11, 2013, 12:25 PM »
DK high flange hubs :daumenhoch:
Hatta headset ???
Offline fischflo
« Reply #2 on: November 11, 2013, 12:29 PM »
flights
tuff peds
tech 4s  ????!?
Offline rooski
  • Mons Veneris
« Reply #3 on: November 11, 2013, 12:31 PM »
Shifter has DX lever :daumenhoch:
Offline rooski
  • Mons Veneris
« Reply #4 on: November 11, 2013, 12:33 PM »
Short Hutch stem lock :daumenhoch:
« Reply #5 on: November 11, 2013, 12:35 PM »
tech 4s  ????!?
I hope it's tech 4s - they're Chris' favourite levers  :teef:
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #6 on: November 11, 2013, 12:42 PM »
tech 4s  ????!?
Looking at the position of the rivet i'd say Tech 3 (sweating emoticon)...
Offline 58 delray
« Reply #7 on: November 12, 2013, 01:33 PM »
both levers look like tech 3s....
tech matic bb
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #8 on: November 12, 2013, 01:35 PM »
Any takers on the seat?
Offline 58 delray
« Reply #9 on: November 12, 2013, 01:40 PM »
looks Elina or kashie mx
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #10 on: November 12, 2013, 01:50 PM »
Which leaves rims and tyres and then i'll have at least one shot at each part...
Offline Bfellows
« Reply #11 on: November 12, 2013, 05:31 PM »
tech 4s  ????!?
There's one on Museum running a lovely set of Tech 4............ http://bmxmuseum.com/bikes/jmc/65694
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #12 on: November 12, 2013, 05:45 PM »
tech 4s  ????!?
And a brown suede seat, need I say more?
« Reply #13 on: November 12, 2013, 06:28 PM »
Every picture of DY personal bikes bitd, he always uses Araya rims, and more often than not chrome 7X rims so I would say that is what he is using here also.
DY mostly used Tuff-Neck stems and in the pictures he is using ODI mushroom grips.
Also if you look closely at the bottom picture, and then look at the bottom of the front rim, you see a faint red smear, I think you will find he is running red nipples on his wheels.
« Last Edit: November 12, 2013, 06:33 PM by stidds »
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #14 on: November 12, 2013, 06:32 PM »
Thanks Sean, would you say the rear is laced 4x?  Would it then make sense that the front would be too?  I always thought 4x was more for freestylers?
Offline Bfellows
« Reply #15 on: November 12, 2013, 06:36 PM »
Definitely looks like a DX / Tech 3 combo.  There's another pic knocking about of a twin speed set up that I think also uses a DX.  I'll see if I can find it.......
« Reply #16 on: November 12, 2013, 06:40 PM »
What I think he is running is 4x racelace, this is where all of the spoke heads face inwards.
Offline Bfellows
« Reply #17 on: November 12, 2013, 06:42 PM »
http://bmxmuseum.com/forums/viewtopic.php?id=36943
Scroll down to the magazine scan.......
« Reply #18 on: November 12, 2013, 06:46 PM »
He is not running a browning two speed though he is running a 2 speed Shimano rear derailleur.
Whereas DY is running a Shimano rear tensioner (I have the same one on my Schwinn Stingray).
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #19 on: November 12, 2013, 06:48 PM »
Mmm, i'm not sure how to do that having only ever laced one set of wheels  "help"
« Reply #20 on: November 12, 2013, 06:52 PM »
Ask and you will receive....
http://bmxmuseum.com/forums/viewtopic.php?id=255583
Offline Macmania
« Reply #21 on: November 12, 2013, 06:56 PM »
Lovely bike but I prefer the one in the background  :D
Wanted: Anything MT Racing
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #22 on: November 12, 2013, 06:58 PM »
Page marked - thanks.
Offline Devilock
« Reply #23 on: November 12, 2013, 08:02 PM »
He wore brown Y fronts.
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #24 on: November 12, 2013, 09:28 PM »
Hopefully you'll let a pair go when I post that wanted ad.
