976236 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 02, 2026, 12:22 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Dodgy dropout!?!?
Author Topic: Dodgy dropout!?!?  (Read 3543 times)
Offline Mikku
  • Keeping it RAD in Japan!
Dodgy dropout!?!?
« on: January 12, 2014, 03:40 PM »
Have spent the weekend going over the Laserlite I've just picked up and have noticed that the right dropout is bent.  :(  My question is how bad do you think it is? This is going to be a weekend rider so it'll need to stand up to a bit (though not alot) of abuse. Here are some pics...
PS If it's bad news please break it to me gently!  :daumenhoch:
Re: Dodgy dropout!?!?
« Reply #1 on: January 12, 2014, 03:43 PM »
Fine that mate  :daumenhoch:
Get it ridden  :)
« Reply #2 on: January 12, 2014, 04:04 PM »
Nothing wrong with that Mikku, whack a wheel in it and it will be fine, or bend it out a bit (don't be too rough with it) either way is good.
« Reply #3 on: January 12, 2014, 04:06 PM »
Be fine once the wheel is in.
To be honest these frames are almost 30 years old now, so gunna be out a bit, bit like the day they were made  :LolLolLolLol:
« Reply #4 on: January 12, 2014, 04:33 PM »
Just leave it between some books and put a bit of weight on it, that'll sort it right out  :daumenhoch:
« Reply #5 on: January 12, 2014, 05:23 PM »
Griff are you really trev ?
Offline Munnyella
« Reply #6 on: January 12, 2014, 05:25 PM »
I love Griff!!
« Reply #7 on: January 12, 2014, 05:26 PM »
NB: this doesn't work on looptails
« Reply #8 on: January 12, 2014, 05:27 PM »
You have to put those in the freezer  :teef:
Offline Mikku
« Reply #9 on: January 14, 2014, 12:39 PM »
Thanks for the replies (and reassurance) - much appreciated!  :)
Offline steve69
  • aka. Steve Changa
« Reply #10 on: January 14, 2014, 03:53 PM »
This is a very easy and effective solution to your problem...
1. One bent drop out (smashed on the floor for demonstration sake)
2. Take a large adjustable spanner (bigger the better for this job) NOTE:- Don't use any spanner or grips that have teeth as it will mark the dropout.
3. Place the spanner on the dropout and adjust it up to a nice tight fit, also make sure you are positioned at the point of the bend.
4. Gently pull the spanner round until straight.
5. Remove spanner and check straightness, refit and tweek if ness.
Hope this helps  :daumenhoch:
« Last Edit: January 14, 2014, 03:56 PM by steve69 »
« Reply #11 on: January 14, 2014, 04:13 PM »
What's a looptail?  ???
Offline Glynnyboy
« Reply #12 on: January 14, 2014, 07:13 PM »
Putting a soft cloth over the drop whilst using the spanner will help too but the pics of the job wouldn't look as good as Steve's .  :)
Offline That Swan Guy
« Reply #13 on: January 14, 2014, 07:19 PM »
Offline Mikku
« Reply #14 on: January 15, 2014, 02:32 PM »
Thanks for that Steve! My only concern about bending it back is whether it will weaken the metal - I'd prefer to have a bent dropout than a broken one!
Offline Glynnyboy
« Reply #15 on: January 15, 2014, 03:58 PM »
Looking at your drop mate I wouldn't have any concerns at all.
Steve's drop in the how to might have made me sweat a bit but yours no.
I do find a vice does a great job too and probably lessens any risk factor you may be worried about.
Offline steve69
  • aka. Steve Changa
« Reply #16 on: January 15, 2014, 08:11 PM »
bending it once or twice is no where near enough to cause fatigue, it certainly won't break.  :daumenhoch:
