976236 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 01, 2026, 08:17 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Hammerite rust remover dip
Author Topic: Hammerite rust remover dip  (Read 4969 times)
Offline nitrohopper
« on: January 21, 2014, 09:00 PM »
Hey guys I have this hammerite rust remover dip and I have a large fiberglass buck type yjing to put mu frame and forks in can anyone help me do I have to cover all.the holes inside the frame to stop soulution getting in has anyone used this product before help needed please it say it dilutes to 10 litre s but the bucket I have is a lot larger and I cant get bike covered with 10 litres help please lads
Offline Munnyella
Re: Hammerite rust remover dip
« Reply #1 on: January 21, 2014, 09:04 PM »
use bottles/jars/bags of water around the frame to displace the good stuff, i.e make it deeper!!
dont cover the holes, it'll be rusty inside too!
MM
« Reply #2 on: January 21, 2014, 09:06 PM »
You didn't spend 20 quid on it did you? ???
Best thing to do is fill plastic bottles full of water and place as many as you can around the frame to consume as much of the spare volume as possible. this should make you ten litres do further but i doubt it will cover the whole fame.
You may have to flip it as one of the chain/seat stays will probably sit out of the liquid  :daumenhoch:
« Reply #3 on: January 21, 2014, 09:09 PM »
In fact now i look at it again, fook that tub off as you are going to need 10 gallons by the look of it, and buy a cheapo 1 meter diameter paddling pool. Inflate and squash to the frames shape. Jobs a good'un :daumenhoch:
« Last Edit: January 21, 2014, 09:13 PM by oldschoolace »
« Reply #4 on: January 21, 2014, 09:23 PM »
I always give frames a Oxy acid bath.
Is that Hammerite stuff better ?
Offline nitrohopper
« Reply #5 on: January 21, 2014, 09:38 PM »
hi guys thanks
no it cost a tenner from ebay
i see what you are saying with tub i may try and get a small swimmong pool tomorrow its just i have dogs and i dont want them drinking from water hence the big tub
i dont know i will let you know
« Reply #6 on: January 21, 2014, 09:45 PM »
Have a look on the tub, alot of anti rust stuff is either Oxalic, phosphoric or citric acid. Not sure on the first two but i always use pure citric acid powder as its cheap and wont kill any seagulls  ;)
« Reply #7 on: January 21, 2014, 09:50 PM »
The end of the first paragraph tells you all you need to know about how good citirc acid is  :daumenhoch:
http://www.rafmuseum.org.uk/cosford/whats-going-on/news/dornier-do-17-progress-featured-on-bbc/
Offline Bfellows
« Reply #8 on: January 21, 2014, 10:07 PM »
Aup Clint, where you get your citric from and what solution? I've picked up a pair if cheap bars I need to tidy up  ;)
Offline chubby
  • Needs Pegs
« Reply #9 on: January 21, 2014, 10:36 PM »
Look after animals lee, some of these potions can be a bit iffy  :daumenhoch:
« Last Edit: January 21, 2014, 10:39 PM by chubby »
« Reply #10 on: January 21, 2014, 10:46 PM »
For small items you can get little tubs in the home brew section of wilko's Bert.
I just shop around on the bay if i'm doing a frame or owt big.
You can run it quite weak, it will just take longer.
This is pretty cheap for the amount:
http://www.ebay.co.uk/itm/Citric-Acid-Powder-1Kg-/360722458396?pt=UK_Health_Beauty_Natural_AlternativeTherapies&hash=item53fcbbe71c
and about half that would give you pretty rapid results on a frameset in a pool/large tub :daumenhoch:
Offline Bfellows
« Reply #11 on: January 21, 2014, 10:58 PM »
Cheers fella  :daumenhoch:
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #12 on: January 21, 2014, 11:10 PM »
Cheap bars...?  ::)
Offline Bfellows
« Reply #13 on: January 22, 2014, 07:35 AM »
Cheap bars...?  ::)
I couldn't resist seeing if you'd comment  ;D
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #14 on: January 22, 2014, 02:51 PM »
Cheap bars...?  ::)
Totally fished in, I should know better  ::)
Offline nitrohopper
« Reply #15 on: January 26, 2014, 02:18 PM »
Ok so I went last night to b and q to find the deco box didnt have any so I plumped for a large tote box then today of to wilkos to get citric acid as I have dogs and wouldnt want them drinking anything dodgy wilko citric acid £1.50 250ml   so I filled box with 40ltrs of water and a kilo of c/acid put the master in and we will see what happens
« Reply #16 on: January 26, 2014, 02:26 PM »
You should start to see bubbles forming on the parts, any really bad rust spot give a rub with a toothbrush every couple of hours  :daumenhoch:
Offline nitrohopper
« Reply #17 on: January 27, 2014, 07:38 PM »
I would like to thank old school ace for advice on citric I thinks its come out real well
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #18 on: January 27, 2014, 10:25 PM »
Great result Lee, this is going to be a sweet survivor  :coolsmiley:
